Cannot see & pair Fibaro FGR-223 (roller shutter 3)
Hi ,
Got new roller shutter and tried to pair it with my smartthings hub v2 eu .
ST doesn’t see the fibaro new device .
I even removed it from the switch and tested it with only line and neutral and it’s not working .
I did the add device steps as the manual says .
  1. power the device
  2. insert ST to pair mode
  3. press 3 time on module button fast
Any Ideas ?
Do anyone have DH for fibaro shutter 3?
There is a thread with a dh for version 2.
I asked the developer if he can support version 3.
He said he will be try as he doesn’t have the module to test.
Hopes it will be nothing take long
Hi Zvika,
I have the same issue, please contact me at shasimon@gmail.com if you have any answers
Simon
please see here
Hi Zvika, is it possible to reach you on whatsapp ?
it will be great help.
Shachar
What is your email?
shachar@s1mon.co.il
Hi,
It has worked ? Smart Things + FGR-223
@anonino.norely Yes - see the thread linked in post 5 for the DH
Hi guys,
Following this threat I was able to add my FGR-223 to Smartthings, but, it is not working as expected. I just have an ON/OFF button instead of an UP and DOWN, and when I press it just moves the blinds a little (not full).
My physical buttons are one press only and then it keeps working automatically until the end or I can stop it clicking the same button again. The same happens to open the blinds.
How can I parameter this?
Thanks in advance for the help.
hello I have the same problem, already managed to solve.
Thank you
