Fibaro FGBS-001
Hello,
All my devices is ok, except my Fibaro Binary Universal (Fibaro FGBS-001) with a ds18b20 (Temp sensor)
He is pairing like a Multichannel Switch but I don’t have any temperatur indication.
All my routines are move from Vera to ST and all device just 2 devices (Comet Zwave and this issue with Fibaro)
Thank for help
OK I try directly :slight_smile:
It’s WORKS !
My move to ST is incredibly good.
Just my two Comet Zwave valves but I was expecting that.
I was afraid to change because I had been with Micasaverde for years, but I’m glad I changed.
The hub seems to me of good quality, the interface is much more friendly and the community is just efficient and fast.
THANKS AGAIN
Could you share the code plz? Just got a SmartThings and moving my Fibaro things.
Got the same as above; Fibaro Binary Universal (Fibaro FGBS-001) with a ds18b20 (Temp sensor).
Would be very happy! =)
I use the UBS but not as a temp sensor, I’ll see if I can quickly modify it to include temp sensors, though it might be a bit of a guess as I don’t think it is well documented (if you’re happy to try a few things I’ll give it a go)
