Hi,
I’ve got 1 Fibaro dimmer 2 + Fibaro ByPass 2. I’ve successfully calibrated and paired the dimmer to my Smarthings and I can turn on/off in the Smarthings app (and also dim it a bit, it doesn’t have the full range).
The big problem is that I can’t use the wall switch. Nothing is happening with the lamp when I turn the switch (which is a toggle), nor there are any logs in Live Logging. Do you know what I’ve can have done wrong? How can I debug this?
Here is a picture of the Fibaro connections: https://photos.app.goo.gl/uex71uk1R2G5qhTTA
Here is a picture of the switch (I’ve tested it on another place and it is working): https://photos.app.goo.gl/wYqSkHLxHQ2Gz6pQ7
Here is a picture of how I connected the Bypass: https://photos.app.goo.gl/CEgn64xRNPQ8VjUYA
My end goal is to remove the lamp and only use it to control the other devices in the room via Scene commands
Here are my settings I’ve changed (taken from smarthings IDE):
|configProactiveReports|boolean|false|
|configProtectLocal|enum|2|
|configProtectRF|enum|0|
|configSyncAll|boolean|false|
configParam32 enum 1
configParam28 enum 1
configParam20 enum 1
configParam13 enum 2
|configLoggingLevelDevice|enum|2|
|configLoggingLevelIDE|enum|4|
|configNightmodeForce|boolean|false|
|configNightmodeLevel|number|20|
