Have you tried running the z-wave network repair utility (its under hub on IDE) I ran it several times while trying to resolve my issues, but not sure if its needed or not. It did identify a missing device which I removed. (manually added with the same z-wave address, then deleted it)
yes ran it many times no luck on the dimmer function on fibaro. works only like a switch
I’ve not come across that myself. Have you tried different device handlers? I’ve heard some work better than others, even when the rev no on the fibaros is the same, some work with one DH but not another.
ok will look at it to night. have a power shortage at my location atm
