@anonino.norely - I agree with Borris, I expect that you need to exclude (through the ST dashboard) the UBS and then repair it, since it seems like the contact/motion sensors are working but the temperatures are coming back blank…
Device excluded and included again, but temperature sensors doesn’t work… How can I do a debug?
When I send config from ST…
Can you try filling in the values for every config parameter with the defaults. That should fix it, meanwhile I will look to fix that!
Despite this, it wont fix your temperature not appearing sadly. Are they all connected to the correct three cables of the UBS?
Brilliant, no worries I’ll give it a try and let you know
Hi,
I’m trying but no luck… I installed four new temperature sensors DSB18B20, exclude, include, change device handler, but temperature don’t show, contact sensors works well.
GND -> UBS BLUE
VDD -> UBS BROWN
DATA -> UBS WHITE
Are the wires just the length that you can see in the picture? I.e. they arent extended too far inside a cavity or something.
Also does it show any differences in behaviour when only one sensor is plugged in, rather than 4?
Have you tried power cycling the UBS? I know its a silly statement, but perhaps it needs a power cycle aswell as exclude/include. It certainly seems the problem is on the UBS end since the DTH never receives any temperature information according to those logs.
Yes, cable length is 1 meter. Same behavior with one or four sensors, several factory resets, include, exclude.
I will test the same UBS on a Fibaro HC2 on Friday.
Hi,
I bought a new UBS and 4 new DSB18B20. I repeated the entire installation process, it shows the temperature of only one probe.
Any ideas ?
Thanks!.
Ah cool you got it working!
Was it just a case of going through the setup one more time?
As for only slowing one temperature, that is a bug of mine, I’ll try and fix it in the next day or two, it’s an easy fix but I couldn’t test it as I only have one sensor connected.
Got it all going and it works brilliant thanks!
The things I noticed is I dont see the temperature updating in the IDE logs?
In webCoRE the attributes come up as a contact and motion rather than 2 contacts?
Personally I would prefer to see the temperature as the master so when you see the devices in the app you can quickly see the temperature.
This DH is without a doubt the best one I have seen for the UBS, so for other users is it possible to be able select 2 contacts or a motion sensor and a contact in the option settings or something?
Had a look though the code so am I right in saying it essentially pull the DH from ST library? so if they update it it would update them anyway?
I made a few changes that means you can use it directly in webCoRE with out the the need of the child devices, what do you think? The CC is just in reference to 2 contacts as i also going to try and make a contact and motion one. But Im hoping you will be able to combine them and create a option for the two in the parameter menu or something? Then with the 2 combo it will create child devices when needed ie contact, motion and temp but if you don’t need them ie just one contact you wont need it
* Device Type Definition File
* Device Type: Fibaro UBS (CC) - Dual Contact and Temperature Sensor
* File Name: Fibaro UBS (CC) - Dual Contact and Temperature Sensor.groovy
* Initial Release: 2017-11-07
* Author: Chris Charles
* Copyright 2017 Chris Charles, based on original code by carlos.ir33, modified
* by Stuart Buchanan and Paul Crookes
metadata {
definition (name: "Fibaro UBS (CC)", namespace: "cjcharles0", author: "Chris Charles") {
capability "Contact Sensor"
capability "Motion Sensor"
capability "Sensor"
capability "Temperature Measurement"
capability "Configuration"
command "removeChildDevices"
command "updateCurrentParams"
command "listCurrentParams"
command "open1"
command "open2"
command "close1"
command "close2"
attribute "contact1","enum",["open1","close1"]
attribute "contact2","enum",["open2","close2"]
fingerprint type: "2001", cc: "30,60,85,8E,72,70,86,7A,EF"
simulator {
tiles(scale: 2) {
standardTile("contact1", "device.contact1", width: 3, height: 2) {
state "open", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#e86d13", action: "close1"
state "closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#00a0dc", action: "open1"
standardTile("contact2", "device.contact2", width: 3, height: 2) {
state "open", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#e86d13", action: "close2"
state "closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#00a0dc", action: "open2"
standardTile("temp1text", "temp1text", inactiveLabel: false, decoration: "flat", width: 2, height: 1) {
state "default", label:'Temp 1:', action:"", icon:""
standardTile("temp2text", "temp2text", inactiveLabel: false, decoration: "flat", width: 2, height: 1) {
state "default", label:'Temp 2:', action:"", icon:""
standardTile("temp3text", "temp3text", inactiveLabel: false, decoration: "flat", width: 2, height: 1) {
state "default", label:'Temp 3:', action:"", icon:""
standardTile("temp4text", "temp4text", inactiveLabel: false, decoration: "flat", width: 2, height: 1) {
state "default", label:'Temp 4:', action:"", icon:""
valueTile("temperature1", "temperature1", width:1, height:1, decoration: "flat") {
state "default", label:'${currentValue}°', unit:"C", backgroundColor:"#fab907", icon:"st.Weather.weather2"
valueTile("temperature2", "temperature2", width:1, height:1, decoration: "flat") {
valueTile("temperature3", "temperature3", width:1, height:1, decoration: "flat") {
valueTile("temperature4", "temperature4", width:1, height:1, decoration: "flat") {
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat", width: 2, height: 1) {
state "configure", label:'Send Config', action:"configuration.configure", icon:"st.secondary.configure"
standardTile("report", "device.configure", inactiveLabel: false, decoration: "flat", width: 2, height: 1) {
state "report", label:'List Config', action:"listCurrentParams"
standardTile("removechildren", "removechildren", inactiveLabel: false, decoration: "flat", width: 2, height: 1) {
state "default", label:'Remove Child Devices', action:"removeChildDevices"
main(["temperature1"]) //, "contact2"
details(["contact1","contact2",
"temp1text", "temperature1", "temp2text", "temperature2",
"temp3text", "temperature3", "temp4text", "temperature4",
"configure", "report", "removechildren"])
preferences {
def paragraph = "Device Handler by @cjcharles \n\n"
input("childcontact1", "bool", title: paragraph + "Create Child Contact1 Device?", required:false, displayDuringSetup: true)
input("childcontact2", "bool", title:"Create Child Contact2 Device?", required:false, displayDuringSetup: true)
paragraph = "Parameter Settings:\n\n"
input name: "param1", type: "number", range: "0..65535", required: false, //defaultValue: "0",
title: paragraph + "Parameter No. 1 - Input 1 Alarm Cancellation Delay. \n" +
"Additional delay after an alarm from input 1 has ceased.\n" +
"Time in seconds to delay the ceasing event.\n" +
"Default value: 0."
input name: "param2", type: "number", range: "0..65535", required: false, //defaultValue: "0",
title: "Parameter No. 2 - Input 2 Alarm Cancellation Delay. \n" +
"Additional delay after an alarm from input 2 has ceased.\n" +
"Default value: 0."
input name: "param3", type: "number", range: "0..3", required: false, //defaultValue: "1",
title: "Parameter No. 3 - Type of Input No 1." +
"Available settings:\n" +
"0 – INPUT_NO (Normal Open)\n" +
"1 – INPUT_NC (Normal Close)\n" +
"2 – INPUT_MONOSTABLE\n" +
"3 – INPUT_BISTABLE\n" +
"Default value: 1."
input name: "param4", type: "number", range: "0..3", required: false, //defaultValue: "1",
title: "Parameter No. 4 - Type of Input No 2." +
"Default value: 1."
input name: "param5", type: "number", range: "0..255", required: false, //defaultValue: "255",
title: "Parameter No. 5 - Type of transmitted control or alarm frame for association group 1." +
"0 – Frame ALARM GENERIC\n" +
"1 – Frame ALARM SMOKE\n" +
"2 – Frame ALARM CO\n" +
"3 – Frame ALARM CO2\n" +
"4 – Frame ALARM HEAT\n" +
"5 – Frame ALARM WATER\n" +
"255 – Control frame BASIC_SET\n" +
"Default value: 255."
input name: "param6", type: "number", range: "0..255", required: false, //defaultValue: "255",
title: "Parameter No. 6 - Type of transmitted control or alarm frame for association group 2." +
input name: "param7", type: "number", range: "0..255", required: false, //defaultValue: "255",
title: "Parameter No. 7 - Value of the parameter specifying the forced level of dimming / opening sun blinds when " +
"sent a “switch on” / ”open” command from association group no. 1.\n" +
"0-99 - Dimming or Opening Percentage\n" +
"255 - Last set percentage\n" +
input name: "param8", type: "number", range: "0..255", required: false, //defaultValue: "255",
title: "Parameter No. 8 - Value of the parameter specifying the forced level of dimming / opening sun blinds when " +
"sent a “switch on” / ”open” command from association group no. 2.\n" +
input name: "param9", type: "number", range: "0..3", required: false, //defaultValue: "0",
title: "Parameter No. 9 - Deactivating transmission of the frame cancelling the alarm or the " +
"control frame deactivating the device (Basic). Disable the alarm cancellation function.\n" +
"0 – Cancellation sent for association group 1 and 2\n" +
"1 – Cancellation sent for association group 1 only\n" +
"2 – Cancellation sent for association group 2 only\n" +
"3 - Not sent for association group 1 or 2\n" +
"Default value: 0."
input name: "param10", type: "number", range: "1..255", required: false, //defaultValue: "20",
title: "Parameter No. 10 - Interval between successive readings of temperature from all " +
"sensors connected to the device. (A reading does not result in sending to ST)\n" +
"1-255 - Seconds between readings\n" +
"Default value: 20."
input name: "param11", type: "number", range: "0..255", required: false, //defaultValue: "200",
title: "Parameter No. 11 - Interval between forcing to send report of the temperature. " +
"The forced report is sent immediately after the next temperature reading, " +
"irrespective of parameter 12. Advised to be 200 unless rapid temperature changes are expected.\n" +
"0 - Deactivate temperature sending\n" +
"1-255 - Seconds between sends\n" +
"Default value: 200."
input name: "param12", type: "number", range: "0..255", required: false, //defaultValue: "8",
title: "Parameter No. 12 - Insensitiveness to temperature changes. This is the maximum " +
"difference between the last reported temperature and the current temperature. " +
"If they differ by more than this then a report is sent.\n" +
"0-255 - x/16 = temp diff in C\n" +
"x/80*9 = temp diff in F\n" +
"Default value: 8 (0.5oC)."
input name: "param13", type: "number", range: "0..3", required: false, //defaultValue: "0",
title: "Parameter No. 13 - Transmitting the alarm or control frame in “broadcast” mode (i.e. to " +
"all devices within range), this information is not repeated by the mesh network." +
"0 - IN1 and IN2 broadcast inactive,\n" +
"1 - IN1 broadcast mode active only,\n" +
"2 - IN2 broadcast mode active only,\n" +
"3 - INI and IN2 broadcast mode active.\n" +
"Default value: 0."
input name: "param14", type: "number", range: "0..1", required: false, //defaultValue: "0",
title: "Parameter No. 14 - Scene activation functionality." +
"0 - Deactivated functionality,\n" +
"1 - Activated functionality.\n" +
"Default value: 0."
def installed() {
log.debug "installed()"
def updated() {
log.debug "updated()"
createChildDevices()
def uninstalled() {
log.debug "uninstalled()"
removeChildDevices()
def configure() {
log.debug "configure"
delayBetween([
zwave.multiChannelAssociationV2.multiChannelAssociationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format(),
zwave.associationV2.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format(),
zwave.associationV1.associationRemove(groupingIdentifier:1, nodeId:zwaveHubNodeId).format(),
zwave.configurationV1.configurationSet(parameterNumber: 1, configurationValue:[param1.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 2, configurationValue:[param2.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 3, configurationValue:[param3.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 4, configurationValue:[param4.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 5, configurationValue:[param5.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 6, configurationValue:[param6.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 7, configurationValue:[param7.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 8, configurationValue:[param8.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 9, configurationValue:[param9.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 10, configurationValue:[param10.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 11, configurationValue:[param11.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 12, configurationValue:[param12.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 13, configurationValue:[param13.value]).format(),
zwave.configurationV1.configurationSet(parameterNumber: 14, configurationValue:[param14.value]).format(),
], 500)
private void createChildDevices(){
log.debug "Adding Child Devices if they are configured"
if (childcontact1) {
log.debug "Creating Contact1 child"
try {
def currentchild = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-contact1"}
if (currentchild == null) {
addChildDevice("smartthings/testing", "Simulated Contact Sensor", "${device.deviceNetworkId}-contact1", device.hub.id, //cjcharles0 Visonic Contact Zone
[completedSetup: true, name: "${device.displayName} (Contact1)", label: "${device.displayName} (Contact1)", isComponent: false])
} catch (e) {
log.debug "Error adding Contact1 child: ${e}"
if (childcontact2) {
log.debug "Creating Contact2 child"
try {
def currentchild = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-contact2"}
addChildDevice("smartthings/testing", "Simulated Contact Sensor", "${device.deviceNetworkId}-contact2", device.hub.id, //cjcharles0 - Visonic Contact Zone
[completedSetup: true, name: "${device.displayName} (Contact2)", label: "${device.displayName} (Contact2)", isComponent: false])
} catch (e) {
log.debug "Error adding Contact2 child: ${e}"
private removeChildDevices(){
log.debug "Removing Child Devices"
try {
getChildDevices()?.each {
deleteChildDevice(it.deviceNetworkId)
} catch (e) {
log.debug "Error deleting ${it}, either it didn't exist or probably locked into a SmartApps: ${e}"
def result = null
def cmd = zwave.parse(description, [ 0x60: 3])
if (cmd) {
result = zwaveEvent(cmd)
log.debug "parsed '$description' to result: ${result}"
return result
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv1.ManufacturerSpecificReport cmd) {
log.debug("ManufacturerSpecificReport ${cmd.inspect()}")
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
log.debug("ConfigurationReport ${cmd.inspect()}")
def createEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd, Map item1) {
log.debug "manufacturerId: ${cmd.manufacturerId}"
log.debug "manufacturerName: ${cmd.manufacturerName}"
log.debug "productId: ${cmd.productId}"
log.debug "productTypeId: ${cmd.productTypeId}"
def createEvent(physicalgraph.zwave.commands.versionv1.VersionReport cmd, Map item1) {
updateDataValue("applicationVersion", "${cmd.applicationVersion}")
log.debug "applicationVersion: ${cmd.applicationVersion}"
log.debug "applicationSubVersion: ${cmd.applicationSubVersion}"
log.debug "zWaveLibraryType: ${cmd.zWaveLibraryType}"
log.debug "zWaveProtocolVersion: ${cmd.zWaveProtocolVersion}"
log.debug "zWaveProtocolSubVersion: ${cmd.zWaveProtocolSubVersion}"
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
log.debug "BasicSet V1 ${cmd.inspect()}"
def currentstate
if (cmd.value) {
currentstate = "open"
} else {
currentstate = "closed"
createEvent(name: "contact1", value: currentstate, descriptionText: "${device.displayName} is ${currentstate}")
try {
def childDevice = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-contact1"}
if (childDevice)
childDevice.sendEvent(name: "contact", value: currentstate)
} catch (e) {
log.error "Couldn't find child device, probably doesn't exist...? Error: ${e}"
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
log.debug "ZWaveEvent V3 ${cmd.inspect()}"
def result
if (cmd.commandClass == 32) {
def currentcontact
def currentstate
if (cmd.parameter == [0]) {
if (cmd.sourceEndPoint == 1) {
currentcontact = "contact1"
//result = createEvent(name: "contact1", value: "closed", descriptionText: "$device.displayName is closed")
//log.debug "Contact1 is closed"
else
if (cmd.sourceEndPoint == 2) {
currentcontact = "contact2"
//result = createEvent(name: "contact2", value: "closed", descriptionText: "$device.displayName is closed")
//log.debug "Contact2 is closed"
if (cmd.parameter == [255]) {
//result = createEvent(name: "contact1", value: "open", descriptionText: "$device.displayName is open")
//log.debug "Contact1 is open"
else
//result = createEvent(name: "contact2", value: "open", descriptionText: "$device.displayName is open")
//log.debug "Contact2 is open"
log.debug "${currentcontact} is ${currentstate}"
sendEvent(name: currentcontact, value: currentstate, descriptionText: "$device.displayName - ${currentcontact} is ${currentstate}")
if (childcontact1 && (currentcontact == "contact1")) {
try {
def childDevice = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-${currentcontact}"}
if (childDevice)
} catch (e) {
if (childcontact2 && (currentcontact == "contact2")) {
try {
if (childDevice)
} catch (e) {
} else {
def encapsulatedCommand = cmd.encapsulatedCommand([0x31: 2, 0x60: 3, 0x85: 2, 0x8E: 2, 0x72: 1, 0x70: 1, 0x86: 1, 0x7A: 1, 0xEF: 1, 0x2B: 1]) // can specify command class versions here like in zwave.parse
log.debug ("Command from endpoint ${cmd.sourceEndPoint}: ${encapsulatedCommand}")
if (encapsulatedCommand) {
result = zwaveEvent(encapsulatedCommand)
return result
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv2.SensorMultilevelReport cmd)
log.debug "Sensor MultiLevel Report - Sensor Type = ${cmd.sensorType}"
switch (cmd.sensorType) {
case 1:
// temperature
def cmdScale = cmd.scale == 1 ? "F" : "C"
def tempval = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision).toDouble().round(1)
sendEvent(name: "temperature1", value: tempval, displayed: false) //unit: getTemperatureScale()
break;
log.debug map
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv1.SensorMultilevelReport cmd) {
log.debug "SensorMultilevelReport $cmd"
// This will capture any commands not handled by other instances of zwaveEvent
// and is recommended for development so you can see every command the device sends
log.debug "Catchall reached for cmd: ${cmd.toString()}}"
return createEvent(descriptionText: "${device.displayName}: ${cmd}")
def listCurrentParams() {
log.debug "Listing of current parameter settings of ${device.displayName}"
def cmds = []
cmds << zwave.multiChannelAssociationV2.multiChannelAssociationGet(groupingIdentifier:2).format()
cmds << zwave.associationV2.associationGet(groupingIdentifier: 3).format()
cmds << zwave.associationV1.associationGet(groupingIdentifier: 1).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 1).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 2).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 3).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 4).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 5).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 6).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 7).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 8).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 9).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 10).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 11).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 12).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 13).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber: 14).format()
delayBetween(cmds, 500)
def open1() {
sendEvent(name: "contact1", value: "open", descriptionText: "$device.displayName (1) is opened manually")
try {
if (childDevice)
childDevice.sendEvent(name: "contact", value: "open")
} catch (e) {
def close1() {
sendEvent(name: "contact1", value: "closed", descriptionText: "$device.displayName (1) is closed manually")
try {
if (childDevice)
childDevice.sendEvent(name: "contact", value: "closed")
} catch (e) {
def open2() {
sendEvent(name: "contact2", value: "open", descriptionText: "$device.displayName (2) is opened manually")
try {
def childDevice = getChildDevices()?.find { it.deviceNetworkId == "${device.deviceNetworkId}-contact2"}
if (childDevice)
} catch (e) {
def close2() {
sendEvent(name: "contact2", value: "closed", descriptionText: "$device.displayName (2) is closed manually")
try {
if (childDevice)
} catch (e) {
Making the temperature main is easy (just write temperature1 in the main
section right at the top).
I’ll check out the contact motion option for webcore, and fix that. It is
definitely better to use the child sensors though… I’ve also noticed that
because I left the state flags (to choose if you want child devices) that
everything runs quite slowly so I might turn that feature off…
Havnt noticed this? What do you mean, so then you can’t create the child devices? For me it seemed faster but that’s probably where I messed up the previous code and yours is much neater. So if you think you can improve it even, more brilliant!
Agreed, but some of the uses I have for them they work perfectly without as there only doing basic stuff. But having the option to do both is brilliant
. I tested both the add and remove child device buttons and they work perfectly! So much easier to than manually doing it! Just a shame that ST don’t have a simulated contact sensor that is view only that you could use.
edit: unless its possible to link to my one I changed?
Yep worked this out and also re put in the temperature icon and colour so that it looks good on the app. Al them changes are on the code above. I also did a motion one but need to test that and work out how to create a child for it.
I too am unable to view any temperature readings.
If I have 1 probe I get 3 endpoints, when I have 4 probes I get 6 endpoints, so the UBS must be detecting the probes.
You seemed to need to buy a new UBS to get it to work. Was the old one faulty? We’re you able to return it?
Any suggestions are welcome. (Yes, I exclude and include any time I make changes to the UBS )
The first two are the inputs and then the subsequent ones are the temperature readings. Our they should be! I’d love to have a look at your logs when I’m home next weekend and can try and understand what is happening
Today I do not know why first ubs did not work, I changed it to a new one and it worked.
I’m sorry I can not help you. Can you attach logs ?
I really appreciate your helping me.
How do I access the logs?
Do I have to enable debug?
I was a programmer but I am very new to Smartthings.
Hi, don’t worry, I have only one month with smartthings, it’s easy to learn.
See attached screenshoot, “Live Logging” and then select device name.
another interesting point of information is in “Devices” -> Sensor -> List Events.
Excellent!
The 'live logging ’ tag was obscured by a logon message…
Now that I can see what’s happening, I will explore my problem some more…
It has started to work!
I connected 4 sensors, did an exclude/include, configured with default settings and am now getting a reading for temperature1.
Looking at the code, it just sets temperature1
Is there a more recent version that does all 4?
