I would say no as it worked for me as I have the dimmer behind the metal backbox ( as too small for the module but has a gap by the supporting beam) and a metal Schneider screwless plate and had no problem pairing and working with the smartthings hub one floor below and hiding behind a office desk.
it may be different if you have concrete walls though
Phil, I used those Varilight retractive switches (mixture of 2,3 and 4 gang) for 32 fibaro dimmer 2 circuits and 5 fibaro relay circuits. However, the backboxes were plastic. Works fine.
I’ve got about 10 of these now working in brick walls with metal backboxes and metal faceplates. All seem to be working reliably - although it’s still early days for me.
I used rmbhatia Rajiv code from Sep '15 - Saved and published to the device obvisouly, go to the app click on it and the light flick on and more or less straight away they turn off!!
Thanks, I it was a while ago but I think I was asking why triple click didn’t work on S1. I didn’t have a switch connected to S2. I’ve been using that app an have a double click turn the lamps on and off. And on my switch in the lounge that has S2 the second switch toggles the laps on and off. It works great.
I’ve read somewhere recently that the new device handler has instructions for getting the association working so the dimmer can directly control other devices without going through the hub, but I’ve not tried this yet.
Yup, using this device handler you can configure device assocations (including multi-channel associations) The direct communication between devices typically gives a much quicker response then relying on a smartapp.
OK - So I have managed to sort my problem, I had a faulty dimmer 2 exchanged it and installed the new one. Same code switch works on/off but hardly dims the LED bulbs? I have enough load around 120w - They are dimmable with an ordinary dimmer.
Auto-calibration has probably been overly-conservative determining the min and max dimming levels. Check what it’s set them as and adjust as necessary.
I have install the Fibaro dimmer 2 in my hallway and connected to LED Dimmerable GU10 bulbs. I can dim them perfectly from the App, but when I select a routine which I have created which under motion lights will come on and set to 20%, they will only go to full 100%.
Hi everybody, i need your help. i bought a Fibaro Dimmer 2 to use with my Smart Things but no success so far. Can you please direct me to the following:
Where can i download the latest code to add so i can have all the functionality?
Any step by step guide on how to install and the cables?
I have only 2 cables, not 3. does that work?
any other recommendation? does it work with non-dimmable lights as well? in 2 cable setup?
If you have a two wire setup with non-dimmable loads (I guess LEDs?), then you will need the Fibaro Bypass 2, otherwise your LEDs will glow when they are off.
Technically if you have a non dimmable load you may need one anyway or it could cause damage to the device while the Fibaro forces some residual current through it… But with good quality kit you’re probably right
Hoping someone here can help me solve a bit of a mystery. I’ve been using the Fibaro Dimmer 2’s(without issue) for the past 6months. All of a sudden today none of the dimmers are responding to ST/webcores request to turn on(they still work manually from the wall switch).
What is odd is that when I go into ST’s app and look at the ‘Recently’ tab, I can see the state of the dimmers and their power consumption, however if I click ‘Turn on/off’ nothing happens.
This has happened to all(about 8) of the units I’m using around the house and I can’t figure out what is going on. I have rebooted the hub and tried cycling power to the lighting ring to see if I could reestablish the connection, but it’s as if they no longer no how to respond to the ‘On’ command.
Live logging only shows one line when trying: 6:28:59 PM: info on(): Turning dimmer on.
I have about 30 dimmers in my house and this happens occasionally to me too. Recalibrating the dimmer normally sorts this out. I think it is parameter 12 or 13
