The Gentle Wake Up SmartApp is working wonderfully for me, but I need just ONE MORE feature to make it perfect for my use case. I need to be able to set the color before the ramping begins. I find it quite odd that this SmartApp supports a gradual change of color, but does not allow for setting what that color is!
My use case is to simulate a sunrise early in the morning, even before the real sunrise (while it is still dark outside). Problem is, I will have often set this same bulb’s color to red the evening before, but I want it to gradually wake me up the next morning with a very white to blueish color. I need to be able to specify the color as an RGB value, NOT a simple “yellow”, “green”, etc.
Is this the proper place to make such feature requests? I am a programmer, so I could probably modify the code myself, but I don’t yet understand what to then do with the modified source code, e.g. how to “apply” it for use. Where are those instructions located?
