Hey guys,
I’m using smartthings wifi 3 pack as my home router/wifi. I had 1 dead spot in my house and wanted to buy an extra smartthings wifi, but accidentally got a smarththings hub v3. I added it in my smartthings app as a network extender, but it doesn’t seem it’s extending my wifi signal at all.
So my question is, can I use the hub v3 as a repeater at all? If not, can I set it up as the main hub and use the other 3 wifis as repeaters? Or should I just try to sell it off and get another smartthings wifi module?
thanks in advance
I made this same mistake. The v3 doesn’t work with the mesh system at all.
Hub v3 has no wifi capabilities.
sell it off and get another ST wifi module
It has a Wi-Fi radio, unlike the V2, but it cannot participate in the Wi-Fi mesh network.
The only 2 hub models which can build a Wi-Fi mesh are the original “smartthings connect home“ which has been discontinued, and the current “Samsung smartthings Wi-Fi with plume.“ and you cannot mix and match these with each other, as they use different Wi-Fi mesh architecture.
https://support.smartthings.com/hc/en-us/articles/207477083-Which-SmartThings-Hub-do-I-have-
thanks a lot guys, I thought I was going crazy. The naming of these products could be more straight forward.
Correct, it can connect to WiFi, it cannot broadcast.
I know this won’t matter to anybody else, but since I was a network engineer…
It can definitely broadcast, that’s how it connects to Wi-Fi. It just can’t help establish a WiFi mesh network, which is a different function.
