I all, i am new to this forum and am wondering if anyone has created a code for the Everspring Dimmer module. The module itself seems quite good but i have it connected to a standard switch, when i turn the switch on the light constantly dims on and off. I need to change parameter 4 from 0 to 1 that will enable the dimmer module to use the switch in toggle mode instead of single pole double throw.
If nobody has created a code i am happy with some help from you guys to create and publish the code.
any help would be much appreciated.
