Hi,
In my place I have a light that is controlled by 3 switches. Each of the switch can turn on and off the light. I want to install a In-Wall Everspring Dimmer Module AD146 but I’m not sure how to connect the wires.
The device that I currently have is this one:
Device instructions:
My wall switches have the following configuration:
From my analysis I believe I should place in in-wall switch on the last switch the one with 3 wires that connect to the light bulb. But I’m not sure what wires to connect to each pin on the z-wave device. Also this device has a pin called 3V is this a 3 volatage pin (the wires seem to be thinner for this pin) ? What to I connect here ?
Can someone help me on this ?
Thank you.
Daniel
