I’m trying to follow the below tutorial and at the beginning I’m already facing an error. When I run “smartthings edge:drivers” I get “Error: LoginAuthenticator credentials file not set.”
Hi, @DavinD!
Which version of the CLI are you using? (run smartthings or smartthings --version commands)
Also, can you enable the debug mode to see if we can get more details about this issue, please?
If using Linux/Mac OS:
SMARTTHINGS_DEBUG=true smartthings <command>
If using Windows:
//first
set SMARTTHINGS_DEBUG=true
//then
smartthings command
