tonesto7
(Anthony S.)
April 28, 2015, 5:06pm
1
Hello Everyone,
I’m still new to this groovy\smartthings programming and i am trying to pull in my home energy use. I’ve tried searching for tutorials for beginners on this stuff, but i’m struggling to get my bearings.
The API url is "https://engage.efergy.com/mobile_proxy/getInstant?token=APITOKENHERE "
It returns this JSON:
last_reading_time: 1429546828000,
reading: 622
Could someone point me to a similar Device Type and Smart App i can mirror off of?
kris
(Kris Schaller)
April 28, 2015, 5:21pm
2
Hey @tonesto7 ,
Have you seen the developer docs for this yet? They’re a great resource. We’re planning on releasing some walk-throughs for more of these issues that are pain-points for beginners.
http://docs.smartthings.com/en/latest/smartapp-developers-guide/calling-web-services-in-smartapps.html
Jim
(Jim Anderson)
April 28, 2015, 5:28pm
3
There’s also an example here of using httpGet to call a Weather Underground API.
Here is a fairly simple device type that does basically the same thing. https://github.com/AndyRawson/SmartThings/blob/master/SparkThings/sparkthings-devicetype.groovy
Something like this should work for you:
private checkStatus() {
def readingClosure = {
response -> response.data.each {
item ->
log.debug "age: $item.age"
log.debug "last reading time: $item.last_reading_time"
log.debug "reading: $item.reading"
httpGet("https://engage.efergy.com/mobile_proxy/getInstant?token=${token}", readingClosure)
tonesto7
(Anthony S.)
April 28, 2015, 5:50pm
5
Seriously everyone thanks for the prompt reply’s.
I really appreciate the code Andy i will try it out.
I will need a device type now correct?
Any suggestions there?
tonesto7
(Anthony S.)
April 28, 2015, 5:52pm
6
Nevermind the last question… I viewed the code from the spark things device
tonesto7
(Anthony S.)
April 28, 2015, 6:39pm
7
Here is my device type:
preferences {
input "token", "text", title: "Access Token", required: true
metadata {
definition (name: “Efergy Engage Elite Energy Monitor”, namespace: “tonesto7”, author: “tonesto7”) {
capability “Energy Meter”
capability “Polling”
simulator {
// TODO: define status and reply messages here
tiles {
valueTile(“energy”, “device.energy”, decoration: “flat”) {
state “default”, label:‘${currentValue} kWh’
main (["energy"])
log.debug “Parsing ‘${description}’”
// handle commands
def poll() {
log.debug “Executing ‘poll’”
getReading()
// Get the sensor reading
private getReading() {
response → response.data.each {
item →
log.debug “age: $item.age”
log.debug “last reading time: $item.last_reading_time”
log.debug “reading: $item.reading”
Unfortunately its not returning any data. I can see the empty log entries for the Age, last_reading, and reading.
Thoughts?
See what you are getting back with this:
response ->
log.debug "result: $response.data"
Then we can go from there.
AndyRawson
(Andy Rawson)
April 29, 2015, 12:18pm
10
Ok, then this should work.
response ->
log.debug "age: $response.data.age"
log.debug "last reading time: $response.data.last_reading_time"
log.debug "reading: $response.data.reading"
AndyRawson
(Andy Rawson)
April 29, 2015, 1:20pm
12
Ok, testing with https://engage.efergy.com/mobile_proxy/getInstant shows that they return it as Content-Type: text/html instead of Content-Type: application/json so it looks like if we modify the content type in the httpGet we should get proper JSON back.
response ->
def params = [
uri: "https://engage.efergy.com",
path: "/mobile_proxy/getInstant?token=${token}",
contentType: 'application/json'
httpGet(params, readingClosure)
tonesto7
(Anthony S.)
April 29, 2015, 4:37pm
13
I made the changes you suggested and this is the output.
0d00b71d-9f55-4eec-ba0a-4d12ed5d8722 12:27:34 PM: debug reading: null
0d00b71d-9f55-4eec-ba0a-4d12ed5d8722 12:27:34 PM: debug last reading time: null
0d00b71d-9f55-4eec-ba0a-4d12ed5d8722 12:27:34 PM: debug age: null
0d00b71d-9f55-4eec-ba0a-4d12ed5d8722 12:27:34 PM: debug result: [status:error, description:bad token]
0d00b71d-9f55-4eec-ba0a-4d12ed5d8722 12:27:34 PM: debug Executing ‘poll’
How would I config the polling frequency?
Here is the full code:
preferences {
metadata {
definition (name: "Efergy Engage Elite Energy Monitor", namespace: "tonesto7", author: "tonesto7") {
capability "Energy Meter"
capability "Polling"
simulator {
tiles {
valueTile("energy", "device.energy", decoration: "flat") {
state "default", label:'${currentValue} kWh'
main (["energy"])
log.debug "Parsing '${description}'"
// handle commands
def poll() {
log.debug "Executing 'poll'"
getReading()
response ->
def params = [
AndyRawson
(Andy Rawson)
April 29, 2015, 4:43pm
14
Looks like the token is bad now but it is returning as JSON with the square brackets. [status:error, description:bad token]
I use Pollster to handle polling frequency changes. I haven’t looked into any other ways.
tonesto7
(Anthony S.)
April 30, 2015, 1:46pm
15
I am very appreciative of the time you’ve given to help through this so thanks…
The token still works if I use it with previous function you sent. So something is missing with the new code.
I will use the pollster since I am using it for something else till i get better with the code to integrate it.
AndyRawson
(Andy Rawson)
April 30, 2015, 5:59pm
16
Hmm, it looks like the query part may need to be broken out when the path is split from the uri.
response ->
def params = [
path: "/mobile_proxy/getInstant",
query: ["token": token],
Almost there…
tonesto7
(Anthony S.)
April 30, 2015, 6:21pm
17
Amazing! that was it…
0d00b71d-9f55-4eec-ba0a-4d12ed5d8722 2:18:01 PM: debug reading: 680
0d00b71d-9f55-4eec-ba0a-4d12ed5d8722 2:18:01 PM: debug last reading time: 1430417879000
0d00b71d-9f55-4eec-ba0a-4d12ed5d8722 2:18:01 PM: debug age: 2
0d00b71d-9f55-4eec-ba0a-4d12ed5d8722 2:18:01 PM: debug result: [last_reading_time:1430417879000, reading:680, age:2]
0d00b71d-9f55-4eec-ba0a-4d12ed5d8722 2:18:00 PM: debug Executing 'poll'
So what variable would I reference for the tiles label to show the “reading”?
AndyRawson
(Andy Rawson)
April 30, 2015, 9:04pm
18
You would probably want to use something like this right after the log.debug lines
sendEvent(name: "energy", value: response.data.reading)
tonesto7
(Anthony S.)
May 1, 2015, 4:46pm
19
Thanks for your help. Its working great.
