[Edge] How can I safely dispose socket?
I built a driver using UDP socket.
But when I install that driver, then it freeze whole hub about few days later.
After digging in, I found a reason and problematic codes.
That was memory leak and caused by creating socket.
Here is a simplest code to reproduce.
The result of running driver is, increasing memory usage as shown.
2022-07-15T08:28:39 DEBUG LAN BinarySwitch  DEBUG       Current Memory usage: 352.6KiB
2022-07-15T08:28:40 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:28:49 DEBUG LAN BinarySwitch  DEBUG       Current Memory usage: 354.6KiB
2022-07-15T08:28:50 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:28:59 DEBUG LAN BinarySwitch  DEBUG       Current Memory usage: 356.2KiB
2022-07-15T08:29:00 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:29:09 DEBUG LAN BinarySwitch  DEBUG       Current Memory usage: 357.3KiB
2022-07-15T08:29:10 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:29:19 DEBUG LAN BinarySwitch  DEBUG       Current Memory usage: 359.0KiB
2022-07-15T08:29:20 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:29:29 DEBUG LAN BinarySwitch  DEBUG       Current Memory usage: 360.4KiB
2022-07-15T08:29:30 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:29:39 DEBUG LAN BinarySwitch  DEBUG       Current Memory usage: 361.8KiB
2022-07-15T08:29:40 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:29:49 DEBUG LAN BinarySwitch  DEBUG       Current Memory usage: 364.1KiB
2022-07-15T08:29:50 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:29:59 DEBUG LAN BinarySwitch  DEBUG       Current Memory usage: 365.7KiB
2022-07-15T08:30:00 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:30:10 DEBUG LAN BinarySwitch  DEBUG       Current Memory usage: 367.0KiB
2022-07-15T08:30:10 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:30:20 DEBUG LAN BinarySwitch  DEBUG       Current Memory usage: 368.1KiB
2022-07-15T08:30:20 DEBUG LAN BinarySwitch  dumy name device thread event handled
And you can comment lines that creating socket,
function lifecycles.init(driver, device)
    device.thread:call_on_schedule(10, function()
        do
            collectgarbage("collect")
            local mem_useage = collectgarbage("count")
            log.debug(string.format("DEBUG\tCurrent Memory usage: %.1fKiB",
                mem_useage))
        end
-       for i = 1, 10 do
-           local sock = assert(socket.udp())
-           sock:setoption("broadcast", true)
-           sock:settimeout(3)
-           sock:close()
-       end
+       -- for i = 1, 10 do
+       --     local sock = assert(socket.udp())
+       --     sock:setoption("broadcast", true)
+       --     sock:settimeout(3)
+       --     sock:close()
+       -- end
    end, "Resync Connectivity")
end
You can see there is no leak.
2022-07-15T08:07:06 DEBUG LAN BinarySwitch  DEBUG   Current Memory usage: 352.1KiB
2022-07-15T08:07:06 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:07:16 DEBUG LAN BinarySwitch  DEBUG   Current Memory usage: 352.1KiB
2022-07-15T08:07:16 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:07:26 DEBUG LAN BinarySwitch  DEBUG   Current Memory usage: 352.1KiB
2022-07-15T08:07:26 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:07:36 DEBUG LAN BinarySwitch  DEBUG   Current Memory usage: 352.1KiB
2022-07-15T08:07:36 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:07:46 DEBUG LAN BinarySwitch  DEBUG   Current Memory usage: 352.1KiB
2022-07-15T08:07:46 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:07:56 DEBUG LAN BinarySwitch  DEBUG   Current Memory usage: 352.1KiB
2022-07-15T08:07:56 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:08:06 DEBUG LAN BinarySwitch  DEBUG   Current Memory usage: 352.1KiB
2022-07-15T08:08:06 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:08:16 DEBUG LAN BinarySwitch  DEBUG   Current Memory usage: 352.1KiB
2022-07-15T08:08:16 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:08:26 DEBUG LAN BinarySwitch  DEBUG   Current Memory usage: 352.1KiB
2022-07-15T08:08:26 DEBUG LAN BinarySwitch  dumy name device thread event handled
2022-07-15T08:08:36 DEBUG LAN BinarySwitch  DEBUG   Current Memory usage: 352.1KiB
2022-07-15T08:08:36 DEBUG LAN BinarySwitch  dumy name device thread event handled
Is it kind of bug or did I wrong at some points?
Additionally here I append my original code.
local function _scan(opt)
    if opt.laddr == "255.255.255.255" then
    end
    sock:settimeout(opt.timeout)
    local scan_msg = format_scan_message(opt.type, opt.mac)
    log.info(string.format("scanning with message: %s", scan_msg))
    assert(sock:sendto(scan_msg, opt.laddr, PORT), "failed to scan device")
    local msgs = {}
    while true do
        --- There are two possible case, [data, ip, port] or [nil, err, nil]
        local buf, ip, port = sock:receivefrom()
        if buf == nil then
            sock:close()
            return msgs
        end
        msgs[#msgs + 1] = buf
        if opt.find_one then
            sock:close()
            return msgs
        end
    end
end
Thank you in advance for your reply.
Hi, @cmsong-shina!
I’m checking more details about this with the engineering team, once we have more info, we’ll let you know.
Very interesting!!
BTW, is there a way restarting driver?
It can be ad-hoc way to keep my hub running.
Following up on this case. @cmsong-shina, could you send me over DM the following info, please?
  • Hub ID
  • Account where it’s installed
Also, the team mentioned that a leak in the driver/runtime isn’t enough to cause the system to be unresponsive, so, we need your authorization to check some internal data of the Hub.
To do so, please follow these steps:
  1. Go to the SmartThings Web (my.smartthings.com 1)
I’ve seen the driver is restarted when the Hub suffered a power outage or when you publish and install a new version.
Thank you for bringing this up, I just wanted to let you know that you have identified a bug that we have a fix for expected in the next release.
There is not at this time a reliable way to restart a single driver on a hub.
