Edge Drivers Z-Wave+ for Homeseer WD/WS100+?
@SameGuy I’d be happy to, but I don’t know what the fingerprint is.
Otherwise, feel free to edit fingerprints.yml and add a profile.
Thank you. Must not be converted to Edge yet. I’m not able to install the driver. Is there anything I need to do to get my account updated to Edge? …Somethign changed months ago. I was blocked from installing/editing smart apps. My switches stopped working. Isn’t that because of the Edge update?
Thanks for the quick response! This is what API Browser+ brings up (sorry, I can’t get it to display the left column on my phone):
What version hub do you have?
EDIT: Has the firmware been updated? (latest versions)
Sorry, @SameGuy, after looking at this closer I see that you’re asking about a sensor, not a switch.
I don’t have any experience with the sensors, and I’m sure that this switch driver won’t work.
However, I did see this thread which includes a driver for a Homeseer sensor, they might be able to help you there: [ST EDGE] Z-Wave Sensor Driver Channel - including specific Ecolink, FortrezZ, HomeSeer and Zooz models
Awesome, thanks, sorry to confuse things from my end. Some of us (procrastinators) have been waiting til things broke before searching for fixes, so of course there’s a bit of flailing as we (I) try to come up with solutions. I hadn’t seen that thread in my searches yet. :+1:t3:
Ok. Thank you for your help!
@ryanjmulder
Just as an FYI, I just opened a pull request to incorporate some additional work. Your posting was a good chance for me to jump into these Edge Drivers with both feet.
Please let me know if you want to go this contribution route, or if I should generate a new channel invite. The initial commit burst was meant to help build out the fingerprints/profiles/preferences/configurations, and to emulate the Community structure. Now that is in-place, I was looking to properly add additional functionality for dimmer rates etc.
PS – I have largely ignored the fan capabilities, but at first blush, it looks like both 3-speed and 4-speed capabilities exist in the default zwave-fan driver.
@jshessen WOW! I was dreaming of building out this driver someday when I had time, and I’m so glad that you did. I can handle the PRs and packaging if you want, but it probably makes more sense for you to take over this driver, if you’ve got the time and the passion for it.
If you want to post an invite link here, I’ll edit my posts and readme to point to yours.
I moved the conversation about the new version to its own thread so that’s the one that will show up in the community-created wiki quick browse lists now and it will be easier to find. :sunglasses:
Here’s the new thread:
[BETA] Edge Drivers for Homeseer Devices
Can you add mfg 0184 for hs/hd100 switch. Official driver doesn’t support ws100 switch. Your driver installed on one ws100 switch and not the others.
zw:L type:1001 mfr:0184 prod:4447 model:3033 ver:5.15 zwv:4.24 lib:03 cc:5E,86,72,5A,85,59,73,25,27,70,2C,2B,5B,7A ccOut:5B
@ryanjmulder I’ve added the “Unofficial” drivers and changed my switches to “HomeSeer Z-Wave Switches,” but I’m not seeing the multi-tap options? Under Attributes > supportedbuttonvalues I’m only seeing [“pushed”,“held”]? Am I doing something wrong? These are also the only ones presented when creating new Routines.
NM. I removed and re-added my switches and all appears to be working normal. Thanks!
