I did the changes @Mariano_Colmenarejo
Switch came out as 4 tiles. Still cannot control on/off from app.
2023-07-16T12:29:16.055275606+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:16.071763273+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={key_attributes="KEY_RELEASED", scene_number=1, sequence_number=92, slow_refresh=false}, cmd_class="CENTRAL_SCENE", cmd_id="NOTIFICATION", dst_channels={}, encap="NONE", payload="\x5C\x01\x01", src_channel=0, version=3}
2023-07-16T12:29:16.123447273+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch
2023-07-16T12:29:16.141606939+00:00 WARN Z-Wave Switch INT Attempted to generate event for 08800706-b176-495d-8aa5-b3513b118635.main but it does not support capability Button
2023-07-16T12:29:16.153513939+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:16.154619939+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:16.156246606+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={value=255}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={1}, encap="NONE", payload="\xFF", src_channel=1, version=1}
2023-07-16T12:29:16.183543939+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch -> multi metering switch
2023-07-16T12:29:16.184369939+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> emitting event: {"state":{"value":"on"},"capability_id":"switch","component_id":"main","attribute_id":"switch"}
2023-07-16T12:29:16.186091273+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:20.804399940+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:20.812815606+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={value=255}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={2}, encap="NONE", payload="\xFF", src_channel=2, version=1}
2023-07-16T12:29:20.826464606+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch -> multi metering switch
2023-07-16T12:29:20.853240273+00:00 INFO Z-Wave Switch INT <ZwaveChildDevice: a7d5d0c7-14ee-491c-9585-14c3bd6272b7 [08800706-b176-495d-8aa5-b3513b118635][02] (WYFY Switch 2)> emitting event: {"state":{"value":"on"},"capability_id":"switch","component_id":"main","attribute_id":"switch"}
2023-07-16T12:29:20.860716940+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:20.867583273+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:20.868846607+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={key_attributes="KEY_RELEASED", scene_number=2, sequence_number=93, slow_refresh=false}, cmd_class="CENTRAL_SCENE", cmd_id="NOTIFICATION", dst_channels={}, encap="NONE", payload="\x5D\x01\x02", src_channel=0, version=3}
2023-07-16T12:29:20.885745940+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch
2023-07-16T12:29:20.892709940+00:00 WARN Z-Wave Switch INT Attempted to generate event for 08800706-b176-495d-8aa5-b3513b118635.main but it does not support capability Button
2023-07-16T12:29:20.896182607+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:22.471034940+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:22.484399940+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={value=255}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={3}, encap="NONE", payload="\xFF", src_channel=3, version=1}
2023-07-16T12:29:22.492715273+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch -> multi metering switch
2023-07-16T12:29:22.503248273+00:00 INFO Z-Wave Switch INT <ZwaveChildDevice: a5eb1d40-b3b5-4ab2-a02d-1dd9f27d4f78 [08800706-b176-495d-8aa5-b3513b118635][03] (WYFY Switch 3)> emitting event: {"state":{"value":"on"},"capability_id":"switch","component_id":"main","attribute_id":"switch"}
2023-07-16T12:29:22.543201607+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:22.544049273+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:22.547790273+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={key_attributes="KEY_RELEASED", scene_number=3, sequence_number=94, slow_refresh=false}, cmd_class="CENTRAL_SCENE", cmd_id="NOTIFICATION", dst_channels={}, encap="NONE", payload="\x5E\x01\x03", src_channel=0, version=3}
2023-07-16T12:29:22.565321940+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch
2023-07-16T12:29:22.572309607+00:00 WARN Z-Wave Switch INT Attempted to generate event for 08800706-b176-495d-8aa5-b3513b118635.main but it does not support capability Button
2023-07-16T12:29:22.577016940+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:23.908542274+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:23.916233274+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={key_attributes="KEY_RELEASED", scene_number=4, sequence_number=95, slow_refresh=false}, cmd_class="CENTRAL_SCENE", cmd_id="NOTIFICATION", dst_channels={}, encap="NONE", payload="\x5F\x01\x04", src_channel=0, version=3}
2023-07-16T12:29:23.920661274+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch
2023-07-16T12:29:23.951109940+00:00 WARN Z-Wave Switch INT Attempted to generate event for 08800706-b176-495d-8aa5-b3513b118635.main but it does not support capability Button
2023-07-16T12:29:23.955354607+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:23.964072274+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:23.965334607+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={value=255}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\xFF", src_channel=0, version=1}
2023-07-16T12:29:23.968294940+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch -> multi metering switch
2023-07-16T12:29:23.969469607+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:23.970664607+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:23.979810607+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={value=255}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={4}, encap="NONE", payload="\xFF", src_channel=4, version=1}
2023-07-16T12:29:23.989906607+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch -> multi metering switch
2023-07-16T12:29:24.000130940+00:00 INFO Z-Wave Switch INT <ZwaveChildDevice: 79fabdf8-81b4-4590-a5fa-a4161064f722 [08800706-b176-495d-8aa5-b3513b118635][04] (WYFY Switch 4)> emitting event: {"state":{"value":"on"},"capability_id":"switch","component_id":"main","attribute_id":"switch"}
2023-07-16T12:29:24.010210274+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:29.704277941+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:29.706128274+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={key_attributes="KEY_RELEASED", scene_number=1, sequence_number=96, slow_refresh=false}, cmd_class="CENTRAL_SCENE", cmd_id="NOTIFICATION", dst_channels={}, encap="NONE", payload="\x60\x01\x01", src_channel=0, version=3}
2023-07-16T12:29:29.728511941+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch
2023-07-16T12:29:29.741765608+00:00 WARN Z-Wave Switch INT Attempted to generate event for 08800706-b176-495d-8aa5-b3513b118635.main but it does not support capability Button
2023-07-16T12:29:29.753132608+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:29.754222608+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:29.755887274+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={value=0}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={1}, encap="NONE", payload="\x00", src_channel=1, version=1}
2023-07-16T12:29:29.783605941+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch -> multi metering switch
2023-07-16T12:29:29.784420608+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> emitting event: {"state":{"value":"off"},"capability_id":"switch","component_id":"main","attribute_id":"switch"}
2023-07-16T12:29:29.786128941+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:30.437828274+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:30.445613941+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={value=0}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={2}, encap="NONE", payload="\x00", src_channel=2, version=1}
2023-07-16T12:29:30.537464608+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch -> multi metering switch
2023-07-16T12:29:30.548009941+00:00 INFO Z-Wave Switch INT <ZwaveChildDevice: a7d5d0c7-14ee-491c-9585-14c3bd6272b7 [08800706-b176-495d-8aa5-b3513b118635][02] (WYFY Switch 2)> emitting event: {"state":{"value":"off"},"capability_id":"switch","component_id":"main","attribute_id":"switch"}
2023-07-16T12:29:30.576829941+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:30.577670941+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:30.579308941+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={key_attributes="KEY_RELEASED", scene_number=2, sequence_number=97, slow_refresh=false}, cmd_class="CENTRAL_SCENE", cmd_id="NOTIFICATION", dst_channels={}, encap="NONE", payload="\x61\x01\x02", src_channel=0, version=3}
2023-07-16T12:29:30.598313941+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch
2023-07-16T12:29:30.605955274+00:00 WARN Z-Wave Switch INT Attempted to generate event for 08800706-b176-495d-8aa5-b3513b118635.main but it does not support capability Button
2023-07-16T12:29:30.608476941+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:31.111170608+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:31.122838608+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={value=0}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={3}, encap="NONE", payload="\x00", src_channel=3, version=1}
2023-07-16T12:29:31.129663608+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch -> multi metering switch
2023-07-16T12:29:31.140565941+00:00 INFO Z-Wave Switch INT <ZwaveChildDevice: a5eb1d40-b3b5-4ab2-a02d-1dd9f27d4f78 [08800706-b176-495d-8aa5-b3513b118635][03] (WYFY Switch 3)> emitting event: {"state":{"value":"off"},"capability_id":"switch","component_id":"main","attribute_id":"switch"}
2023-07-16T12:29:31.168936608+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:31.170057608+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:31.181834608+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={key_attributes="KEY_RELEASED", scene_number=3, sequence_number=98, slow_refresh=false}, cmd_class="CENTRAL_SCENE", cmd_id="NOTIFICATION", dst_channels={}, encap="NONE", payload="\x62\x01\x03", src_channel=0, version=3}
2023-07-16T12:29:31.189345608+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch
2023-07-16T12:29:31.196974941+00:00 WARN Z-Wave Switch INT Attempted to generate event for 08800706-b176-495d-8aa5-b3513b118635.main but it does not support capability Button
2023-07-16T12:29:31.198287608+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:31.830953941+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:31.835278941+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={key_attributes="KEY_RELEASED", scene_number=4, sequence_number=99, slow_refresh=false}, cmd_class="CENTRAL_SCENE", cmd_id="NOTIFICATION", dst_channels={}, encap="NONE", payload="\x63\x01\x04", src_channel=0, version=3}
2023-07-16T12:29:31.849329941+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch
2023-07-16T12:29:31.872778274+00:00 WARN Z-Wave Switch INT Attempted to generate event for 08800706-b176-495d-8aa5-b3513b118635.main but it does not support capability Button
2023-07-16T12:29:31.884767941+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:31.885627941+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:31.887276274+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={value=0}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={}, encap="NONE", payload="\x00", src_channel=0, version=1}
2023-07-16T12:29:31.889110274+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch -> multi metering switch
2023-07-16T12:29:31.890293274+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:31.901676608+00:00 TRACE Z-Wave Switch INT Received event with handler unnamed
2023-07-16T12:29:31.902950941+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received Z-Wave command: {args={value=0}, cmd_class="BASIC", cmd_id="REPORT", dst_channels={4}, encap="NONE", payload="\x00", src_channel=4, version=1}
2023-07-16T12:29:31.923122941+00:00 TRACE Z-Wave Switch INT Found ZwaveDispatcher handler in zwave_switch -> multi metering switch
2023-07-16T12:29:31.934032274+00:00 INFO Z-Wave Switch INT <ZwaveChildDevice: 79fabdf8-81b4-4590-a5fa-a4161064f722 [08800706-b176-495d-8aa5-b3513b118635][04] (WYFY Switch 4)> emitting event: {"state":{"value":"off"},"capability_id":"switch","component_id":"main","attribute_id":"switch"}
2023-07-16T12:29:31.943937274+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:38.354352275+00:00 TRACE Z-Wave Switch INT Received event with handler capability
2023-07-16T12:29:38.401693942+00:00 TRACE Z-Wave Switch INT Z-Wave command(66a0c7fc) queued for radio transmission: CC:Switch Multi-level, CID:0x01
2023-07-16T12:29:38.404946275+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> received command: {"component":"main","command":"on","positional_args":{},"args":{},"capability":"switch"}
2023-07-16T12:29:38.408477942+00:00 TRACE Z-Wave Switch INT Found CapabilityCommandDispatcher handler in zwave_switch
2023-07-16T12:29:38.423500609+00:00 TRACE Z-Wave Switch INT SWITCH_MULTILEVEL supported.
2023-07-16T12:29:38.424732609+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> sending Z-Wave command: {args={duration="default", value="ON_ENABLE"}, cmd_class="SWITCH_MULTILEVEL", cmd_id="SET", dst_channels={1}, encap="AUTO", payload="\xFF\xFF", src_channel=0, version=2}
2023-07-16T12:29:38.446209609+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:38.461031275+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:38.521645275+00:00 TRACE Z-Wave Switch INT Z-Wave command(66a0c7fc) transmit status: TRANSMIT_COMPLETE_OK
2023-07-16T12:29:43.362089609+00:00 TRACE Z-Wave Switch INT Received event with handler capability
2023-07-16T12:29:43.454352609+00:00 TRACE Z-Wave Switch INT Z-Wave command(7fa45c6b) queued for radio transmission: CC:Switch Multi-level, CID:0x01
2023-07-16T12:29:43.462001943+00:00 INFO Z-Wave Switch INT <ZwaveChildDevice: a7d5d0c7-14ee-491c-9585-14c3bd6272b7 [08800706-b176-495d-8aa5-b3513b118635][02] (WYFY Switch 2)> received command: {"component":"main","command":"on","positional_args":{},"args":{},"capability":"switch"}
2023-07-16T12:29:43.472593276+00:00 TRACE Z-Wave Switch INT Found CapabilityCommandDispatcher handler in zwave_switch
2023-07-16T12:29:43.473782943+00:00 TRACE Z-Wave Switch INT SWITCH_MULTILEVEL supported.
2023-07-16T12:29:43.474945943+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> sending Z-Wave command: {args={duration="default", value="ON_ENABLE"}, cmd_class="SWITCH_MULTILEVEL", cmd_id="SET", dst_channels={2}, encap="AUTO", payload="\xFF\xFF", src_channel=0, version=2}
2023-07-16T12:29:43.494195943+00:00 DEBUG Z-Wave Switch INT WYFY Switch 2 device thread event handled
2023-07-16T12:29:43.498278943+00:00 DEBUG Z-Wave Switch INT WYFY Switch 2 device thread event handled
2023-07-16T12:29:43.526696609+00:00 TRACE Z-Wave Switch INT Z-Wave command(559161ac) queued for radio transmission: CC:Switch Multi-level, CID:0x02
2023-07-16T12:29:43.542393943+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> sending Z-Wave command: {args={}, cmd_class="SWITCH_MULTILEVEL", cmd_id="GET", dst_channels={1}, encap="AUTO", payload="", src_channel=0, version=1}
2023-07-16T12:29:43.549754609+00:00 DEBUG Z-Wave Switch INT WYFY Switch 1 device thread event handled
2023-07-16T12:29:43.629710276+00:00 TRACE Z-Wave Switch INT Z-Wave command(7fa45c6b) transmit status: TRANSMIT_COMPLETE_OK
2023-07-16T12:29:43.700649276+00:00 TRACE Z-Wave Switch INT Z-Wave command(559161ac) transmit status: TRANSMIT_COMPLETE_OK
2023-07-16T12:29:48.273120276+00:00 TRACE Z-Wave Switch INT Received event with handler capability
2023-07-16T12:29:48.371701276+00:00 TRACE Z-Wave Switch INT Z-Wave command(2077a2a7) queued for radio transmission: CC:Switch Multi-level, CID:0x01
2023-07-16T12:29:48.375008610+00:00 INFO Z-Wave Switch INT <ZwaveChildDevice: a5eb1d40-b3b5-4ab2-a02d-1dd9f27d4f78 [08800706-b176-495d-8aa5-b3513b118635][03] (WYFY Switch 3)> received command: {"component":"main","command":"on","positional_args":{},"args":{},"capability":"switch"}
2023-07-16T12:29:48.392414943+00:00 TRACE Z-Wave Switch INT Found CapabilityCommandDispatcher handler in zwave_switch
2023-07-16T12:29:48.393616276+00:00 TRACE Z-Wave Switch INT SWITCH_MULTILEVEL supported.
2023-07-16T12:29:48.394791610+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> sending Z-Wave command: {args={duration="default", value="ON_ENABLE"}, cmd_class="SWITCH_MULTILEVEL", cmd_id="SET", dst_channels={3}, encap="AUTO", payload="\xFF\xFF", src_channel=0, version=2}
2023-07-16T12:29:48.438865276+00:00 DEBUG Z-Wave Switch INT WYFY Switch 3 device thread event handled
2023-07-16T12:29:48.450456610+00:00 DEBUG Z-Wave Switch INT WYFY Switch 3 device thread event handled
2023-07-16T12:29:48.512439276+00:00 TRACE Z-Wave Switch INT Z-Wave command(5089d84d) queued for radio transmission: CC:Switch Multi-level, CID:0x02
2023-07-16T12:29:48.521678276+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> sending Z-Wave command: {args={}, cmd_class="SWITCH_MULTILEVEL", cmd_id="GET", dst_channels={2}, encap="AUTO", payload="", src_channel=0, version=1}
2023-07-16T12:29:48.530321276+00:00 TRACE Z-Wave Switch INT Z-Wave command(2077a2a7) transmit status: TRANSMIT_COMPLETE_OK
2023-07-16T12:29:48.553168610+00:00 DEBUG Z-Wave Switch INT WYFY Switch 2 device thread event handled
2023-07-16T12:29:48.629705610+00:00 TRACE Z-Wave Switch INT Z-Wave command(5089d84d) transmit status: TRANSMIT_COMPLETE_OK
2023-07-16T12:29:50.843216943+00:00 TRACE Z-Wave Switch INT Received event with handler capability
2023-07-16T12:29:50.876633610+00:00 TRACE Z-Wave Switch INT Z-Wave command(c32804c5) queued for radio transmission: CC:Switch Multi-level, CID:0x01
2023-07-16T12:29:50.879902943+00:00 INFO Z-Wave Switch INT <ZwaveChildDevice: 79fabdf8-81b4-4590-a5fa-a4161064f722 [08800706-b176-495d-8aa5-b3513b118635][04] (WYFY Switch 4)> received command: {"component":"main","command":"on","positional_args":{},"args":{},"capability":"switch"}
2023-07-16T12:29:50.881240943+00:00 TRACE Z-Wave Switch INT Found CapabilityCommandDispatcher handler in zwave_switch
2023-07-16T12:29:50.882539610+00:00 TRACE Z-Wave Switch INT SWITCH_MULTILEVEL supported.
2023-07-16T12:29:50.883696943+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> sending Z-Wave command: {args={duration="default", value="ON_ENABLE"}, cmd_class="SWITCH_MULTILEVEL", cmd_id="SET", dst_channels={4}, encap="AUTO", payload="\xFF\xFF", src_channel=0, version=2}
2023-07-16T12:29:50.932500610+00:00 DEBUG Z-Wave Switch INT WYFY Switch 4 device thread event handled
2023-07-16T12:29:50.935662610+00:00 DEBUG Z-Wave Switch INT WYFY Switch 4 device thread event handled
2023-07-16T12:29:51.029633943+00:00 TRACE Z-Wave Switch INT Z-Wave command(c32804c5) transmit status: TRANSMIT_COMPLETE_OK
2023-07-16T12:29:53.451764944+00:00 TRACE Z-Wave Switch INT Z-Wave command(03fd3e84) queued for radio transmission: CC:Switch Multi-level, CID:0x02
2023-07-16T12:29:53.453277277+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> sending Z-Wave command: {args={}, cmd_class="SWITCH_MULTILEVEL", cmd_id="GET", dst_channels={3}, encap="AUTO", payload="", src_channel=0, version=1}
2023-07-16T12:29:53.462856610+00:00 DEBUG Z-Wave Switch INT WYFY Switch 3 device thread event handled
2023-07-16T12:29:53.529715610+00:00 TRACE Z-Wave Switch INT Z-Wave command(03fd3e84) transmit status: TRANSMIT_COMPLETE_OK
2023-07-16T12:29:55.950123277+00:00 TRACE Z-Wave Switch INT Z-Wave command(1750a59c) queued for radio transmission: CC:Switch Multi-level, CID:0x02
2023-07-16T12:29:55.951678277+00:00 INFO Z-Wave Switch INT <ZwaveDevice: 08800706-b176-495d-8aa5-b3513b118635 [37] (WYFY Switch 1)> sending Z-Wave command: {args={}, cmd_class="SWITCH_MULTILEVEL", cmd_id="GET", dst_channels={4}, encap="AUTO", payload="", src_channel=0, version=1}
2023-07-16T12:29:55.960837944+00:00 DEBUG Z-Wave Switch INT WYFY Switch 4 device thread event handled
2023-07-16T12:29:56.037743944+00:00 TRACE Z-Wave Switch INT Z-Wave command(1750a59c) transmit status: TRANSMIT_COMPLETE_OK
Log are as above
