Fingerprints in stock driver
- id: "NEOCoolcam/108D"
deviceLabel: NEO Coolcam Motion/Light Sensor
manufacturerId: 0x0258
productType: 0x0003
productId: 0x108D
deviceProfileName: motion-battery-illuminance
If this is the stock DTH and smartthings hasn’t converted it to edge correctly, you should create a new thread and tag to @nayelyz to create a report or walk you through the steps he should take.
If this is a custom DTH, you should contact the author to see if he will convert it to edge.
I added device because of a user request and changed it to a profile with temperature, but I didn’t add the parameter settings that I see in your DTH capture.
If you want to modify those parameters you can do the following:
- Look in your manual for the parameters and their possible values.
- Install the Z-Wave Device Config Mc driver on your hub.
- perform a driver change to see the current configuration of your device.
- If your configuration is not what you need, read the post on how to use the driver to modify the configuration of the device.
- Once configured, go back to Z-wave Sensor and Child Thermostat Mc driver
