Please try again
Driver time stamp should be
Driver Id 1516dc8e-b6bc-4039-adb3-50af08bc067c
Name Z-Wave Ring Sensor
Package Key zwave-sensor
Version 2024-06-29T15:00:16.106429479
Hi Milan, hoping for a bit of help, having problems with Ring door sensor 2, i have checked and downloaded latest driver version, but not seeing it properly in app. Having read threads, sounds like Z Wave finger prints issue, maybe.
Model no: 0201-0401
Mfg code: 0346-0201-0401
that’s the above details of the device, if you could add to driver when you a few minutes spare, that would be great.
Hi @milandjurovic71 Can you share the fingerprints.yaml for the updated z-wave repeater?, Is your repo public?, if can you share the URL plz.
Thanks,
-g
Sorry I am new to ST world, i am looking fingerprints.yaml for the updated z-wave repeater, that’s the invitation link to the channel, is there a way to pull fingerprints.yaml from there?
If he doesn’t publish his GitHub info, you can get the fingerprints for a driver installed on your hub using the community developed ST API Browser+. Devices->Drivers->“select driver” ->Details. Fingerprints are displayed near the bottom of the driver details.
Yes, if the driver is not owned by you, the API does not includes it the response..
Since then using the information I found, I published a new driver and now the API response includes that
