Never mind, it started working after a while.
Hi Mariano. I have water leak sensor but I dont have driver edge⦠Could You help me?
You have driver in your repository, but when I search new device always install as a zigbee thing. Not a moisture sensor. When I change driver manually to moisture sensor I have information about setting dont load. And water test
false.
Hi, @Zbigniew_Wypij
It should be paired with zigbee moisture Mc driver.
Try to delete zigbee thing Mc and pairs device near of the hub
I will try but when I delete zigbee thing mc and then I install water leak sensor i still have zigbee thing. I dont know what Im doing wrongβ¦![]()
Added to his driver version
You need install this driver version
uninstall device and reinstall device
You do not perform a driver change
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Switch Power Mc
Version 2024-02-12T12:40:12.595075886
- id: "innr/SP 242"
deviceLabel: SP 242 Outlet
manufacturer: innr
model: SP 242
deviceProfileName: switch-power-energy-plug
Many thanks - I deleted the device, updated the driver, however I only have on/off capability showing, nothing for power (nor signal metrics). I have tried reinstalling a few times, and also I deleted the driver and reinstalled, but that didnβt help.
EDIT Itβs just come to life now - ignore me ![]()
Hi,
If you were not able to pair devices directly with the zigbee moisture Mc driver and you made a driver change from zigbee thing Mc, then the device may not have been configured correctly and does not send periodic reports and appears offline after a while.
If it pairs correctly, then it is possible that the zigbee signal is not of sufficient quality or strength.
You should try adding a zigbee repeater, a plug for example, between the devices and the hub
Hi Mariano,
Is it possible to add zigbee dual channel current clamps? (power meter)
Device Information
Manufacturer: _TZE204_81yrt3lo
Model: TS0601
FingerPrinted_EndPoint.ld: 0x01
App Version: 0x4A
ZCL Version: Ox03
Network ID: 0x6711
Zigbee EUI: A4C138358A065E48
Device ID:2aaad65c-b15f-4c16-a18d-
a3c10d7ccf5b
Thank you so much
Edit: I have found additional information at this link:
Hi @Sleck94
Sorry this device uses Tuya cluster EF00 and does not work with standard drivers.
Try with tuya personal EF00 drivers
Hi! @Mariano_Colmenarejo
Can you add the fingerprint profile for this device?
QCSMART 4-BUTTON SWITCH
deviceLabel: βScene Switchβ
manufacturer: β_TZ3000_ufhtxr59β
model: βTS0044β
deviceProfileName: 4-button-battery
i guess that could work under the βZigbee Multi Switch and Child Mcβ driver ?
But it is actually a 4-button scene switch with CR2032 battery.
Thank you for your great work and effort!
Hi @RCBURGOS11
Sorry, I do not have any driver for zigbee multi-buttons
Hello @Mariano_Colmenarejo,
I kindly request adding the HeiHome 2-button switch to βZigbee Multi Switch and Child Mcβ driver.
I appreciate your fantastic efforts as always.
Best Regards.
Name Zigbee Multi Switch and Child Mc
Version 2024-02-15T23:07:42.698237863
- id: "TS0002/_TZ3000_tas0zemd"
deviceLabel: TS0002 Two Switch
manufacturer: _TZ3000_tas0zemd
model: TS0002
deviceProfileName: two-switch
Thank you Sooooooooooooooooooo much!!
Sorry to bother you but I recently purchased the MHCOZY 2 channel relay from Amazon:
MHCOZY 2 Channel 5V 12V ZigBee Smart Relay Switch,Adjustable Self Lock and Momentary Interlock Working Mode,Works with Tuya eWelink Zigbee Gateway, Alexa, Google Home (ZigBee Hub Required) https://a.co/d/4B3MzYD
I have installed and tried multiple drivers from your link and nothing allows me to switch from the default zigbee one except for zigbee thing mc.
I am trying to get this 2 channel relay to work independently so was hoping there was a driver that would do that?
Any help would be greatly appreciated.
Switch to zigbee thing Mc and capture device information needed for add to my driver
Thank you so much for your willingness to assist. I switched over to the zigbee thing mc driver but I am unsure how to capture the information thatβs needed?
After switching over to your driver, when I click on the device I continually get message βthis device hasnβt updated all of its status information yetβ¦check again laterβ
Edit: I believe I found the necessary info u need. I will attach the pics
Hi @Tech_East
Added to this driver version
Version 2024-03-03T15:35:26.828809244
- id: "TS0002/_TZ3000_rulgv5dt"
manufacturer: _TZ3000_rulgv5dt
model: TS0002
