markcarline:
GLEDOPTO GL-C-103P
Hi @markcarline
Added to this driver version
Name Zigbee Light Multifunction Mc
Version 2023-03-21T17:20:23.090491691
- id: "GLEDOPTO/GL-C-103P"
deviceLabel: GLEDOPTO GL-C-103P
manufacturer: GLEDOPTO
model: GL-C-103P
deviceProfileName: rgbw-level-colortemp-2700-6500
@Mariano_Colmenarejo amazing thanks!
which link should i use to install ? (sorry i’m new to this)
EDIT: Ignore me - worked it out thanks anyway
@Mariano_Colmenarejo hmm, not having much luck, i wonder this is an addressable set of LEDS (60x of type WS2812) is there a way to configure that ?
ASP
(Alex Pennington)
March 21, 2023, 8:12pm
859
This is cool and works much faster! But is my understanding correct in that you can only associate a device with one mirror group, not have one device in multiple groups?
What do you mean more specifically?
What is the specific problem?
Yes, only one group per device is correct.
Any other way to do it would be very complicated.
hmm - well i’m a complete beginner so trying to just figure out how I switch on all the leds in the strip. i’ve tried just about everything and the only thing which i have managed to do to get them all to light up is via the “Effects Set Command” and they all come on / off when set to “Blink ON”. Would just like to be able to switch them all on and set a colour. hmm
Hi @markcarline
Do you mean you press the On button and it doesn’t turn on?
If you select a level manually, they don’t turn on either?
If you click on the color wheel or color temperature and select a color or a color temperature, it doesn’t turn on either?
yep tried that nothing happens. hmm
EDIT: The only way i can get any life from it is using “Effects Set Command” = “Blink ON” and then it starts flashing white
markcarline:
nothing happens
Do you get any network error and try again later?
Can you take a screenshot of the device details view?
are you tried with a routine or scene?
No network errors, sure I’ll retest tomorrow.
You mean this?..
markcarline:
You mean this
No, I was referring to a capture like the one I sent you
Hi @Mariano_Colmenarejo , could you please add a Sengled remote to your awesome driver?
“deviceManufacturerCode”: “sengled”
“deviceModel”: “E1E-G7F”
Hi @WallyLviv
Sorry, I have not any driver for multibutton devices
I have another GLEDOPTO to be added. This a RGBCCT GU10 Pro Zigbee 3.0.
Data * application: 01
endpointId: 0B
firmwareFullVersion: 20013001
firmwareImageType: 5172
firmwareManufacturerCode: 4687
model: GL-S-006P
zigbeeNodeType: ROUTER
Raw Description 0B 0104 010D 01 08 0000 0003 0004 0005 0006 0008 0300 1000 01 0019
It works fine with non-edge driver and it has a 2700k to 6500k white range.
Thank you very much!
KrankyFranky:
endpointId: 0B
model: GL-S-006P
Hi @KrankyFranky
Version 2023-03-28T19:36:52.733378487
- id: "GLEDOPTO/GL-S-006P"
deviceLabel: GLEDOPTO GL-S-006P
model: GL-S-006P
Please check your GitHub repo for a pull request to add Sengled E1F-N9G.
It has been fully tested as working in my environment.
As a side note, I was looking at my devices in “graph” and noticed that all of my devices that were switched to your driver show up as though they are DTH devices even though they are clearly using edge drivers.
See here for an example of what I mean: https://imgur.com/a/cPLwdjp
All my other edge devices show up as “placeholder”.
Hi @pbarrette
ElIDE is not used to view information from devices with Edge drivers.
In your screenshot, the last update date was 2022-12-08, when the device should have been migrated
If in the details view, settings menu have the driver option then you are using an Edge driver
You can use this API viewer made by @TAustin
NOTICE!!: SmartThings has now released its own equivalent of this app here , so you may prefer to use that instead.
I have a browser-based web app that provides a point-and-click way to explore most of the SmartThings API. For the non-technical, this gives you access to an important SmartThings resource without having to learn tools like Postman, curl, or the CLI. You don’t even need a computer: a tablet or even smartphone can be used. For the more technically inclined, it provides much faster and more convenient access to those commonly-accessed CLI commands. Although I originally thought of it as a portal for the non-technical, I’ve actually found it quite useful to use during my own development activities.
This is not intended as a replacement or ‘competitor’ to the CLI, mysmart…
I’ll update it when I have a while, I’m a bit busy right now
Version 2023-04-01T16:52:57.808853467
- id: "Sengled/E1F-N9G"
deviceLabel: Sengled E1F-N9G
manufacturer: sengled
model: E1F-N9G
deviceProfileName: switch-level
Is there anyway to actually controller the addressable capabilities of the lights through the integration/gledopto controller? I find it pretty useless and mostly only capable of being used as a standard RGB/W LED strip. Want to be able to control the advanced functions.
