Thanks, I’m not knocking what you’ve done, just disappointed with the lack of function from the device.
Trying to see if anyone had any luck with it in Smartthings.
Don’t know what’s happening. I can get devices off and automatic color change works, but I can’t get devices on. 2 devices stopped working with this driver only one bulb works anymore…
I have aoetec hub and reboot didn’t do anything. Don’t understand this… I have plenty of different drivers and all works. This yours driver did work but about month ago ikea trådfri led driver stopped working and today gledopto driver.
The driver has not been updated since April 1, so nothing has changed in the driver yesterday. I do not understand it either
Name Zigbee Light Multifunction Mc
Version 2023-04-01T16:52:57.808853467
Try to reinstall the device(s) or reinstall the driver using the CLI
Mariano, when I searched for this TS0502B it is listed in your drivers, but as a light bulb? When I added it, it came in under DTH even though I have your Zigbee Thing Mc driver installed, does it need adding to your drivers or is it me?
It is a LED light strip (which of course could be considered a bulb white only 2700-6500K.
Good job, i use this driver for Lidl bulb with ST, all work fine but only the option “ATTEMPT Restore State if Power Lost” doesn’t work!
When the Power Restore the Lidl bulb every time Restore on.
That function doesn’t work on Tuya devices, Lidl brand is Tuya device.
That is why in the preference it says to ATTEMPT, because it is not possible to know in which bulbs it works and which attribute it uses, the zigbee standard or a custom one to create a specific profile for them
Iderwel RGBCCT Zigbee Led Controller 2000K - 6500K
zigbeeNodeType: ROUTER
endpointId: 01
manufacturer: _TZ3210_ijczzg9h
model: TS0505B
I’m using at the moment the Driver for “LAN Hue Color Temperature” which at least goes down to 2200K. But the cold white LEDs still won’t shut completly off for the warmest light. The DTH does only 2700K up.
Your support and efforts in this community is very much appreciated!
