First of all thank you for all your hard work making ST better.
I have a Zigbee LED strip which is currently natively supported in ST but with a DH and not with Edge driver.
Is there any chance you can add it to your driver?
I have some strange issues going on with my hub and one is that sometimes my ikea trΓ₯dfri lights wonβt work correctly. I had your driver and after I changed to basic switch driver they work again. The basic diver doesnβt have the cool dimming function so itβs not as good as your driver was.
Why hue setting goes from 0 to 360 when I select the color in the strip setting but goes from 0 to 100 when Iβve to select a color in a routing?
Itβs a setting problem, a smartings default setting or something else?
I donβt know why that happens to you when they update the HUB firmware. It shouldnβt happen.
It has never happened to me with hub v3 update firmware
How to resolve reinstalling the driver with the CLI?
When the firmware of the hub is updated, it performs a reboot and all the drivers are stopped and reinitialized in the sequence that the hub has programmed.
It is possible that in this sequence the driver does not initialize correctly.
In a normal reboot of the hub, the initialization of the driver works well because it is one of the things that I always test several times.
In some drivers I need to enter delays to configure the device because some environment variables are not immediately available to the driver.
The reboot sequence after the firmware update may require a longer delay on these hubs before initializing the drivers.
Hi @Mariano_Colmenarejo, I am using your βZigbee Multi Switch and Child MCβ edge driver for a tuya 3-gang switch from avatto, I built the module into a fan. Is it possible to add a profile for a fan, so that I can switch the 3 contacts low/medium/high? If 1 of the moduleβs outputs is on, the others must be off. So if Low is on then Mid and High should be off
@Mariano_Colmenarejo I am now using a virtual fan switch with 4 routines (off/low/medium/high). Is it possible to change the layout of the 3-gang switch itself to that of a Fan like the picture I sent?
It is not only a matter of creating a profile to do this. It would be necessary to make a totally different and specific driver and now I canβt do it, sorry
The code is posted on guthub, if anyone wants to do it, but I donβt think I can get much use out of the driver
