I have made the Edge Driver “Zigbee RGB-RGW Light” for the RGB model TRADFRI bulb E27 CWS opal 600lm.
It is made with the default SmartThings Edge libraries.
Try if it works and I will update the list of devices and drivers.
I already have all my zigbee devices running with Edge Drivers. At the moment all works well
I only have 2 Lidl strips with 3 plugs left, until they fix the automation, at least I don’t change them.
Yes, that driver was shared as an example.
So which device are you trying to pair, @troy_owens? You can share a picture of the device specifications (it is generally at the back), or maybe the online user manual.
Thank you for the information. Just to clarify, the issue using the sample is that you don’t receive reports from:
Battery
Vibration
Three-axis value
Only to confirm, do you wait on the “scan nearby” page until you see that the discovered device card appears and a little longer? Eg: 1-3 min
This is because that model might take more time to finish configuration and if you leave the “scan nearby” page before it does, this process is interrupted.
If you confirm the above conditions are met and you still have issues, I will need you to share with me the Hub logs when you pair the device by sending an email to build@smartthings.com.
I can guide you through the CLI configuration as well, but for safety reasons, it would be better to do it privately.
Once the device was installed, did you try to slide your finger across the details screen to refresh the device?
It has ever happened to me that some devices do not offer battery, vibration or 3-axis information when installed and this is solved
I have loaded your “Zigbee Multi Switch Zemismart” driver to experiment with a 3 gang Zemismart switch.
The following are my observations:
All 3 gangs work fine using the physical switch.
All 3 gangs work fine using the manual buttons when I open the device tile in ST.
Gang 1 works good in automations.
When you try to use Gage 2 in an Automation it also controls Gang 1.
When you try to use Gage 3 in an Automation it also controls Gang 1.
You can NOT use Gangs 2 or 3 in WebCore or SharpTools.
Thanks for your hard work on this.
