No. My model is the one with the touch keys.
But they work the same way and with the same DTH
Unlilke when using the DTH, when I added the switch to Edge, it only appeared as one new device. I can only find Switch 2 when I open the newly added switch. From there, I can control both the switches individually.
Is this the same case for you?
The problem is that I just donāt find key two (the non-main one). It gives me the cloud symbol on key two
The problem for the 2 gang, may be that the endpoint of the first switich is ā0Bā and the edge driver assumes for the following switches the endpoint will be 2 and 3, I think they should be 0C, and 0D as it does the DTH.
For the 3 gang, it should work if it is true that the endpoint for switch 1 is 01.
Since I cannot see the debugging logs, I cannot correctly analyze the problem.
Iām going to make some changes to the 2-gang of that model and tests.
I tried the 3 gangs. I see all three of them but I can only control the first one, the other two turn on but then go into a loop.
If I update the key while it is in the loop it exits the loop and executes the command
This is the same as the 3-socket lidl strip.
I am going to make a different driver.
I donāt know what name to give it, hahaha ā¦
You could use āZemiSmart Switch 3 Gangā.
Iām not very creative.
My bad, I must have understood something wrong. Yes, dimmer is capability in every bulb. At least so I thought. But at least your driver works.
@Sakari,
The light model: TRADFRI bulb E27 WS opal 980lm Will be in the zigbee Color Temperature Light driver and zigbee Color Temperature Bulb driver with switch & Level profile.
The one that adjusts the color temperature TRADFRI bulb E27 WW 806lm, will be in the zigbee Color Temperature Light driver and zigbee Color Temperature Bulb driver, with switch-Level-ColorTemperature profile with range 2700k to 6000k
Correct?
Yes, that seems to be right.
I just did scan for rest of the bulbs, found my TRADFRI bulb E27 WW 806lm bulp. Works fine, only dimmer is missing. TRADFRI bulb E27 WS opal 980lm I found too, but it doesnāt work at all.
You already have drivers published..
- Uninstall the devices from the app, always this first.
- Uninstall the hub drivers you used before.
- Install the new vesions of zigbee Color temperature Bulb and Zigbee Color Temperature Light.
zigbee Color temperature ligth is the same as Zigbee Color Temperature Bulb, but this has added progressive on and off. - Install devices.
Slowly, give the hub time to perform install between actions. The App seems to have finished, but in the Hub the process is a little slower.
You can install only one of Driver, the one you are going to use.
If you install the two drivers, devices will join to one of them, we do not know the rules for the Hub choose each to join.
Once they are paired to a driver you can switch from one to the other with the Driver change tool in HUB ā Details menu ā Driver ā Driver Change
The Zigbee Multi Switch Zemismart driver for 2 and 3 gang is already published.
Try if it works and tell me.
The 3 Gang does not work on key three. With key three, key 2 lights up. Key 1 and 2 ok.
2 Gang ok
Sorry, itās my fault and the cut and paste, hahaha ā¦
Uninstall the device and reinstall it, I donāt know if the new version will be installed.
To make sure:
- Remove devices of the driver by uninstalling them with the app
- Remove the driver from the HUb and reinstall it
- Install the device
Found both bulbs and they work. Reaction time might be slightly faster than in build in handler. Dimming works in both but color temperature adjustment should be in TRADFRI bulb E27 WS opal 980lm, not in TRADFRI bulb E27 WW 806lm. Iām pretty sure this is down to my mistake how Iāve āpresentedā my info about bulbs. And thanks for your patience!
Itās already changed in both drivers.
To make sure:
The three gang works.
the two gang to make it work I first have to load another driver that enables me to key 2 then changing the driver with yours both keys work
The multicomponent devices, at the moment do not work well with automations, (yes with smart lighting), the names canāt be changed and displayed separately.
The good thing is that they are all local.
We suppose driver be tested in the beta phase to fix what is not working.
If you see something that does not work well tell me or you can write it yourself in known issues of edge drive thread
These two bulbs I have connected works perfectly! I still have few different kind of bulbs to add. GU13 socket spotlight and two different E14 socket bulbs. But thatās enough for today.
