(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
Switch 2 (2 Gang) does not appear, the cloud symbol appears
I tried to uninstall and reinstall the drivers, to refresh but nothing appears only the main button
I would do one last test:
  • uninstall the devices in the app
  • uninstall the driver from the Hub
  • reboot the Hub or if it is a v3 hub, turn it off for a few seconds and turn it on again
  • install the driver in the Hub
  • Install one of the devices to see if it pairs well
Always the same result. one ok button the other with the cloud symbol
main ok
switch2 cloud symbol
@GiacomoF,
Tomorrow I will make some changes and I will notify you.
With what dth do these double and triple work?
ST Multisensor works well with V3 model but temp and battery reporting does not work on V2
Thank you very much for your interest
The DTH I use is at the following ilnk: zigbee/zemismart zigbee switch DTH (touch).groovy at master · zemismart/zigbee · GitHub
If Hubs have the same firmware version it should work the same on both hubs.
Doesn’t report battery level in detail view?
If you use Android, does the history work well for you?
For me, with the new app update the history sometimes gets blocked or does not show anything.
I have a support ticket open
No, im talking about the version of the sensors themselves, not the hub version…
OIP
OIP (1)
@Mariano_Colmenarejo Wink/GE light bulb and flood light
I have been checking the driver and the part of the miltiv4 sensor, which is manufactured by smartthings, I have not touched anything and I see 2 problems:
  • Regarding the temperature I can fix it, since I modified it for the manufacturer samjin and it ran out of temperature capability for that model. Now I change it and let you know.
  • Regarding the battery, it has a different configuration, in a subdriver, than samjin and the original driver may not work either. I look at that tomorrow and try to correct it.
Anyway, I will also publish the original ST multiporpuese driver so that you can test it on that sensor and tell me if the battery works, the temperature is sure work
@troy_owens,
I already published the original smartthins multipurpose.
try it to see if it works
I do not know those models.
I need to know the model and manufacturer from IDE and the capabilities it has
Thats a no go… temp now registers but still no battery reporting and vibration sensor not working now
Thanks. :pray::pray::blush:
I managed to get one bulb working. It only has color temperature adjustment but no dimming is missing. I’ll try rest of my bulbs after I get back from work.
With original smartthings multipurpose driver?
I understood that TRADFRI bulb E27 WW 806lm only had color temperature adjustment and switch.
Do you also need level adjustment, dimming?
i hope you don’t mind me pitching in. Are you using the same Zemismart Push Switch?
