(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
The automations things a known issue and they are supposed to fix it.
The Switch renaming is know too. I do not if this have solution.
You can try linking switch2 to a virtual switch and imitate their behavior with 2 automations.
It is part of the reasons why I have not released the multi switch driver.
The switch2 thing may have a solution, uninstall it and I will put a new version now.
And you tell me what happens.
I have several different kind of bulbs to test. If you just want to add them. Here’s few different.
  • application: 21
  • endpointId: 01
  • firmwareFullVersion: 23050631
  • firmwareImageType: 8706
  • firmwareManufacturerCode: 4476
  • manufacturer: IKEA of Sweden
  • model: TRADFRI bulb E27 WS opal 980lm
  • zigbeeNodeType: ROUTER
    Raw Description 01 0104 010C 01 09 0000 0003 0004 0005 0006 0008 0300 1000 FC7C 04 0005 0019 0020 1000
  • application: 20
  • endpointId: 01
  • firmwareImageType: 16643
  • model: TRADFRI bulb E27 WW 806lm
    Raw Description 01 0104 0101 01 08 0000 0003 0004 0005 0006 0008 1000 FC7C 04 0005 0019 0020 1000
  • application: 13
  • endpointId: 01
  • firmwareFullVersion: 13013572
  • firmwareImageType: 10241
  • model: TRADFRI bulb E27 CWS opal 600lm
    Raw Description 01 C05E 0200 02 09 0000 0003 0004 0005 0006 0008 0300 0B05 1000 04 0005 0019 0020 1000
@Sakari,
all bulbs are capability switch, level and colortemperature?
@averagebald,
Published
Can try, unistall device and driver and then reinstall driver and device, in this order
Do you want add this single switch to the zigbee switch drive?
I have one similar of this manufacturer
yes, include it in zigbee switch.
it works now after reinstalling. it doesnt switches on and off anymore. thanks for that.
Creating virtual switches allows me to create an automation based on the status of the actual zemismart switches. However, I am still not be able to create an automation that changes the state of SW1 alone since SW2 is selected by default. Hence, i will not be able to change the state of SW1 via motion detection. But no worries, i’m sure someone will fix this soon or maybe there’s another way through this.
I hope this driver will be kept on your channel or get this onboarded on the ST main channel. Thank you so much for your help.
@averagebald,
Try use make automation with smart Ligthing app. You can use the mirror option
Can work well.
In smart lighting you have to search for switch 1 by name and switch2 as switch2
You are right. Then i can mirror each other’s behaviors. Thank you. I really appreciate this a lot!
@GiacomoF,
The 3 switches are already published.
  • the simple on zigbee switch
  • double and triple in zigbee multi switch
Tell me if they work to leave or delete them.
The automation thing, you already know that it is not going well as we talked with @averagebald
First bulb is just plain warm white. Second is white spectrum and last one is RGB.
1 gang is ok.
The two and three gangs do not associate with any drivers.
Sorry,
I had not published the zigbee multi switch. :man_facepalming:
desinstala e instala el driver
you can try now
1 gang ok
2 gangs ok
3 gangs does not bind to the driver
I have redo the fingerprint of the 3 switch
For faster update, you should uninstall the 2 switch device, uninstall the driver of hub and reinstall the driver on the hub
What does this mean?
Has level or colortemperature adjustment?
White from warm to cold, only color temperature adjustment. :blush:
Hi Mariano.
Does not work. On 2 gangs and three gangs only the first button works. The second and third buttons are not managed
If you turn on switch 2 or 3 on the device and do a refresh by sliding your finger on the details screen of the device. Are the status of these switches updated?
The light model: TRADFRI bulb E27 WS opal 980lm is in the zigbee switch driver with light profile
the one that adjusts the color temperature TRADFRI bulb E27 WW 806lm is in the zigbee Color Temperature Light driver with switch-ColorTemperature profile with default range 2000k to 6500k
model: TRADFRI bulb E27 CWS opal 600lm RBD bulb
It would be necessary to make a driver for RGB bulb or add a new profile to one of the existing ones, but it will no longer be today. :woozy_face:
