(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
Hi there, Mariano,
do you think the Shelly 1 gen 4 (non-PM) could work with your Zigbee Switch Mc driver? Currently only stock switch driver works, but I would like to monitor the device metrics. If so I would like to kindly request to add the fingerprint.
Manufacturer: Shelly
Model: S4SW-001X8EU
Hi @TaiNguyen were you able to resolve this?
I have the same model and also can’t choose the MC moisture driver, nor get readings through Wesley’s default clusters.
@dotan_shai any other suggestions?
This should work fine with @w35l3y default Clusters. The sensor is not using EF00 cluster.
the leakage is reporting via cluster 0x0500 which is a standard ZCL cluster. @Mariano_Colmenarejo this should work with your driver as well.
I am no longer using this device with smartthings. There are no compatible driver for this.
That’s a shame.
So are you using it with some other platform?
Hi @Mariano_Colmenarejo,
Could you please add this Moes Flower Plant Monitor to your “Zigbee Moisture Sensor Mc” driver?
- Manufacturer Code: _TZE284_aao3yzhs
  • Model: TS0601
It’s a soil moisture and temperature sensor.
Thank you!
Christian
Hello @Mariano_Colmenarejoďżź
Sorry to bother you.
With Can you create a driver for this device?
Model -
TS0601
Manufacturer Code -
_TZE284_koxaopnk
ďżź
Decidindo -
Manufacturer: \_TZE284_koxaopnk
Model: TS0601
FingerPrinted_EndPoint.Id: 0x01
App Version: 0x4D
ZCL Version: 0x03
Network ID: 0x079D
Zigbee EUI: A4C138E6B8974417
Device ID: 26056db5-9c54-4930-a446-610bf73f5bbd
Server Cluster:
Ep: 0x01={ 0004,0005,EF00,0000,ED00 }
Client Clusters:
Ep: 0x01={ 0019,000A }
Signal Metrics:
LQI: 200 .... RSSI: -63 dbm
Is this data sufficient?
Thank you again
This device uses the custom EF00 tuya cluster.
Try the [ST Edge] Personal Tuya Devices - Generic EF00 Device
These are the DP in use (if needed) :
Hi, thank you very much for the clarification and for sharing the DP mapping.
I’m using Wesley’s Edge Driver – Generic EF00 Device with the device
_TZE284_aa03yzhs.
Based on your message, I understand that the DPs in use are:
  • DP 3 → soil_moisture (raw)
  • DP 5 → temperature (divideBy10)
  • DP 9 → temperature_unit
  • DP 14 → battery_state
  • DP 15 → battery (raw)
At the moment, in the driver configuration UI I can only map DP 3 and DP 5. There is no option available to configure DP 14 or DP 15 for battery.
Also, temperature is reported correctly, but the moisture value is always shown as 100%, which makes me think the DP 3 raw value might need scaling or a different capability mapping.
Could you please advise:
  • If battery (DP 14 / DP 15) is currently supported/exposed in this driver?
  • Whether DP 3 (soil_moisture) requires any conversion or specific capability to avoid the 100% reading?
  • If this device needs a custom profile instead of the generic EF00 configuration?
Thanks again for the help, really appreciate it.
You changed the profile to generic in configuration?
After changing you need to leave device details screen, open that again and open configuration again, so you will be presented a list of sensors you can configure the DPs:
After that you need to add the datapoints to the correct sensor types, you can put multiple DP in the same sensor, comma separated:
For DP 3 you can try “Humidity sensor” and maybe “Battery “ for DP 14,15
Could you please add this curtain motor to your Zigbee Window Treatment Mc driver? It is a Tuya Curtain Motor.
  • Manufacturer: _TZE204_2rvvqjoa
  • Model: TS0601
  • Device Label: Tuya Curtain Motor
Thank you always for your great work!
This device contain cluster EF00 that is not supported by @Mariano_Colmenarejo drivers. You better used @w35l3y Tuya Specific EF00 driver from here:
https://api.smartthings.com/invite/6Vjd4YPVJwjN
These are the DP in use in case needed:
Could you please add this device to your “Zigbee Multi Switch and Child Mc” driver? It is a 2-gang wall switch (Milfra TS0012) but currently, it doesn’t have the backlight setting option.
* Manufacturer: _TZ3000_k008kbls
* Model: TS0012
* Device Label: TS0012 Switch
Here is the device info from Zigbee Thing Mc:
Raw Description: 01 0104 0100 01 07 0000 0003 0004 0005 0006 E000 E001 02 0019 000A
Thank you for your great work!
Hi Mariano, @Mariano_Colmenarejo
Could you please add this Tuya Smart Knob to your “Zigbee Multi Switch and Child Mc” driver?
It is currently detected as a generic switch and I cannot select your driver.
  • Device Label: Tuya Smart Knob
  • Model: TS004F
  • Manufacturer: _TZ3000_kaflzta4
  • Device Profile: basic-switch
Here is the device info screenshot provided by the user:
(Manufacturer Code: _TZ3000_kaflzta4)
Thanks for your amazing work!
Try Erickv button-battery-1.4.5 driver:
[ST Edge] Zigbee Driver for MOES 4-Button Scene Switch (TS004F) Plus Some Smart Knob Models
Or Obmaz zigbee-tuya-button:
Thanks for the referal,@marcos.scheffler
@esoh525 is the device you’re looking to add an actual Knob or it is a 4-button scene switch?
I’m asking because the driver we manage does support the fingerprint you’re looking for, but so far as a 4-switch button.
Install Driver Here
Looking forward to your response.
Could you please add this Tuya CO2 Sensor to your driver?
It is a new fingerprint.
- Manufacturer: _TZE204_3ejwxpmu
- Model: TS0601
- Device Label: Tuya CO2 Sensor
Thanks in advance!
Hi @Mariano_Colmenarejo Please add support for this new revision of this motion sensor to your driver
  "name": "generic-ef00-v1",
  "label": "Generic EF00 Device",
  "deviceManufacturerCode": "_TZ3000_hgbahzmy",
  "manufacturerName": "SmartThingsCommunity",
  "deviceModel": "ZG-204Z",
The box has ZG-204ZL with the "L" adds light/lux sensor (to existing PIR) which is 0 to 1000 lux (or 3000?)
https://imgur.com/a/dC3DpNS
https://www.ebay.com.au/itm/186555619814
This device uses tuya ef00 cluster. See if @wonjj6768 can help, he has drivers for many ZG-204 device models
[ST Edge] Tuya ZG-204ZM Fully Configurable Driver
