Thanks @marcos.scheffler Im new to this and run into trouble right away
Why is the sensor using the driver for Personal Tuya Devices - main / Public SmartThings Edge Drivers - w35l3y ?
@w35l3y driver is a generic driver so, when you add the device, if the fingerprint doesn’t match with an specific driver it will use a generic match.
In fact, @w35l3y driver can work for you if you doesn’t find an specific driver for your device. it is developed to work with devices that use the custom EF00 tuya cluster, you just need to configure the datapoints (Read the [ST Edge] Personal Tuya Devices - Generic EF00 Device to discover how). Datapoint seams to be:
1: occupancy
4: battery
12: illuminance
What is the actual fingerprint for your device? You can find this info in the device details view, open the 3 dots menu and choose “Information”:
_TZ3000_hgbahzmy and ZG-204Z
I found no reference to the datapoints for that specific fingerprint.
Subject: Request to add Fingerprint for Vibration Sensor (HOBEIAN)
Could you please add the following fingerprint to your Zigbee Multi Sensor Mc driver?
It is a Vibration Sensor (Tuya/Hobeian) that is currently being misidentified as a generic Contact Sensor by the default drivers.
Device Details:
Manufacturer Code: HOBEIAN
Model: ZG-102ZM
Raw JSON Data:
JSON
“deviceManufacturerCode”: “HOBEIAN”,
“deviceModel”: “ZG-102ZM”,
“zigbee”: {
"fingerprintType": "ZIGBEE_GENERIC",
"fingerprintId": "contact-generic"
Thank you for your amazing work with these drivers!
Dear @Mariano_Colmenarejo ,
I hope you feeling fine and hope you still willing to help.
My friend have the following Zigbee Siren:
manufacturerName: '_TZ3000_cipibmnp'
model: 'TS0224'
It uses default ZCL clusters:
inClusterList:[1,3,4,5,6,0x300,0x0500,0x0502,0],
outClusterList":[0x0019,0x000A],
Can you please add to Zigbee Siren MC ?
Could you please add this fingerprint to your “Zigbee Moisture Sensor Mc” driver?
Manufacturer: HOBEIAN
Model: ZG-303Z
Hola Mariano, ¿podrías añadir este sensor de humedad de suelo a tu driver para las macetas? Te paso los datos de arriba. Muchas gracias por tu trabajo, un abrazo!
Is it possible to get support for Model ID _TZE204_5slehgeo, a window shutter zigbee device.
That worked perfectly, thanks so much.
Hi all.
I’m experiencing issues with some Moes roller shutter modules (Model name TS130F ; Manufacturer Code _TZ3000_1dd0d5yi), using @Mariano_Colmenarejo window treatment driver.
The percentage update is buggy with one or more happening frequently:
All modules are really close to the hub as it’s a small apartment with plaster walls.
I have the blinds wired to a rocker switch, not a spring momentary switch.
I car about it because I have a window open/close sensor on the bottom rack of the blind to detect premature closure if the blind hits an obstacle. The unreliable % update makes it miss most of the time with false positive and false negative results.
Suggestions will be appreciated.
I use the Zigbee Valve MC driver for a sonoff SWV-BSP valve. It works great so far. On/off and battery. I would need the flow rate. Unfortunatly, it doesn’t appear.
Would it be possible to update the fingerprint and make the flow rate available - especially in routines?
Thanks a lot!
Hello Mariano, this is Lucas from Rio de Janeiro, Brazil!
I would like to request that you include the following Tuya Zigbee motion sensor data in your driver:
Manufacturer
_TZE204_lnbg34rj
Model
TS0601
I would be grateful!
Try any of @wonjj6768 drivers: [ST Edge] Tuya ZG-204ZM Fully Configurable Driver
Instalei todos os drivers edge disponiveis no canal dele que se referia a movimento e presença e o sensor não se conectpu a nenhum! Nem encontrou!
Sou novo nisso, posso estar faz3ndo algo de errado!
Meu sensor é um novadigital zigbee mmw, conhece?
@Patrick_Duarte , do you know any driver that works with this novadigital mmWave sensor?
Hi @Mariano_Colmenarejo,
Could you please add the following fingerprint to your Zigbee Valve Mc driver? This is a Zigbee water timer (SOP10Z).
Manufacturer Code: _TZ3000_cjfmu5he
Model: TS0049
Thank you so much for your great work!
Could you please add this Rain & Light sensor to your Zigbee Tuya Sensor Mc driver?
Manufacturer: _TZE200_u6x1zyv2
Model: TS0601
ClustersInfo: -Ep:Ox01={ 0000,0003,0500,EF00,0001,0400 }
It sends rain/moisture and lux data. Thank you!
Hi. I have the same HOBEIAN/ problem, is your solved?
Could you please add a new fingerprint to your Zigbee Soil Sensor Mc driver?
I have a Tuya Soil Moisture Sensor (model ZG-303Z) that is currently being detected as a standard humidity sensor. I have verified the details using your Zigbee Thing Mc driver:
Model: ZG-303Z
Clusters: It uses the EF00 cluster
Thank you for your great work with these drivers!
