Sorry for not including that!
See attached screenshots
Let me know if this doesnβt have the info you need.
Manufacturer and model are missing, but for temperature and humidity both use cluster EF00 and donβt work with my driver.
Try to use personal EF00 cluster driver.
If necessary these are the data point in for
β1β: βSwitch 1β,
β7β: βTimer 1β,
β14β: βRestart Statusβ,
β19β: βDelay-off Scheduleβ,
β101β: βWork Modeβ,
β102β: βTemp Currentβ,
β103β: βHumidity Valueβ,
β104β: βMaxhum Setβ,
β105β: βMinihum Setβ,
β106β: βUpper Tempβ,
β107β: βLower Tempβ,
β108β: βTemp Correctionβ,
β109β: βHumidity Calibrationβ,
β110β: βFault Stateβ,
β111β: βChild Lockβ,
β112β: βHum Sensitivityβ,
β113β: βTemp Sensitivityβ,
β114β: βAlarmβ,
β115β: βsensor_dectβ,
β116β: βCFβ,
β119β: βswitch_auto_1β,
121 βtemperature alarmβ,
122 βhumidity alarmβ,
123 βalarm switchβ,
I picked up a few of these: https://a.co/d/iwXX5uy
I tried updating itβs drivers to use your βZigbee Thing MCβ but a lot of information is missing, let me know if I can help provide more details:
Model: LNAWTC2WBS
Hi,
I need the manufacturer code too
Hmm, manufacturer was empty/βNullβ, but the advanced portal says manufacturer name is: SmartThingsCommunity and there is no Manufacturer Code. ![]()
You need uninstall device
Install this driver version in your Hub
Pair device with with this driver version
You do not perform a driver change from zigbee thing
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Moisture Sensor Mc
Version 2024-12-23T17:04:41.172573355
- id: "loocam/LNAWTC2WBS"
deviceLabel: loocam Water Sensor
#manufacturer: loocam
model: LNAWTC2WBS
deviceProfileName: moisture-battery
Thank you, it worked. I think the device doesnβt report properly because they all seem βstuckβ in wet state after a test run. I will probably send them back. Thank you for the help!
Hello @Mariano_Colmenarejo
I bought Zigbee Siren Tesla Smart Sensor Siren. I installed your Zigbee Siren drivers, but it seems this one is not on supported list. Could you please add it?
Model: TS0216
Manufacturer code: _TYZB01_4gjtbutf
Hi @Pospitch
Added to this driver version
Have a happy new Year!
Name Zigbee Siren Mc
Version 2024-12-30T19:03:37.886220105
- id : TS0216/_TYZB01_4gjtbutf
deviceLabel : Zigbee Siren
manufacturer : _TYZB01_4gjtbutf
model : TS0216
deviceProfileName : switch-alarm
Thank you very much and I also wish you happy New Year.
I think you didnβt copy last letter from manufacturer code, so itβs not working. It should be _TYZB01_4gjtbutf
Sorry, fixed
Hi,
Happy New Year. Is there a way to create a tilt virtual device? I want to use it for a window with two opening modes, normal and tilt. I want to use both status (normal open, tilt open) from one physical multi purpose sensors for rules.
E.g. a tilted window is ok, a opened window not.
Regards
Thomas
Happy new year too, @tm2023
There is no capability that has the tilt state.
The three-axis capability that uses values ββof +/- 1 g of acceleration cannot be used to make routines either.
The only thing you could do is use 2 multipurpose sensors for each window, one you use with the Magnet for normal opening and the other you use with the garage door option, which is activated by acceleration value between > 900mg = open and < 100 mg = closed, to detect tilt.
Hi,
thanks a lot for your great work. The Zigbee Button mc can create a virtual device for the battery state. Would it also be possible to create a virtual device for the temperature ?
Best regards,
Thomas
Hi,
The battery child device was meant to display the battery status of the different devices connected to the driver, but by removing the possibility of using html text to display the information then it is no longer useful.
I havenβt removed it yet because I had some hope that they would offer an alternative to html text, how naive!!!.
You canβt create a temperature child device.
If it is a smartthings button, you can use the zigbee Temp Sensor with Thermostat Mc driver, to be able to use the temperature sensor as a thermostat.
Thanks a lot for your reply. The Zigbee Button mc is the right driver, i have the aeotec/samjin button. It would just be nice to see the temperature without opening the device.
Iβll see if I can make a mosaic presentation with temperature.
Thanks a lot
Hi,
Try with this driver version
It has a composite tile with button and temperature
Name ST Zigbee Button Mc
Version 2025-01-19T13:30:10.727410572
