@Mariano_Colmenarejo
I have Sonoff SNZB 06P presence sensor, works fine with your drive but there is no illumination values, all the time itβs on 0 or 1.
Can you fix this in the driver? Or itβs just 0 for dim and 1 for bright? ![]()
This device does not inform illuminance values, just dimming or brithg when mition detected
Before I purchase this, I thought I should check with you if you have this model βNAS-AB02BTβ in your Zigbee Siren mc driver. Canβt provide the exact fingerprint yet as I donβt have it yet.
It is not in my driver nor can it be, it uses the EF00 cluster
SH vendor:
_TZE200_t1blo2bj, _TZE204_t1blo2bj
SH model:
TS0601
@Super, Did the Zigbee siren work with Wesleyβs driver?
Support by @w35l3y EF00 driver (personal-tuya-devices)
Many thanks @dotan_shai. I think Marianno gave two fingerprints and am not sure which one this device is going to be so can you confirm if this _TZE204_t1blo2bj also works with Wesleyβs driver?
No problems expected with _TZE204_t1blo2bj:
Could you add this:
basicHtml
TS0601
Model
Manufacturer
_TZE200_a8sdabtg
Networkid
0xAA69
Zigbee EUI
A4C138805B6F55B4
3
11.19
ZCL Version
131
APP Version
Server Clusters
01=(0000,0001,0402, 0405)
Client Clusters
Added to this driver version, try if it works. TS0601 normally does not works and shows values =0.
If it doesnβt work, tell me so I can remove it from the driver.
This device has cluster EF00 hidden and could works with Tuya EF00 personal devices driver.
You need install this driver version in your hub
uninstall device and reinstall device
You do not perform a driver change
βββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Temp Sensor and Child Thermostat Mc
Version 2024-05-24T09:09:19.895325934
- id: "_TZE200_a8sdabt/TS0601"
deviceLabel: Tuya TS0601
manufacturer: _TZE200_a8sdabt
model: TS0601
deviceProfileName: temp-humid-battery # works ??
3 posts were merged into an existing topic: Post Requests for LAN/WIFI Edge Drivers Here (community-created)
Name Zigbee Motion Sensor Mc
Version 2024-06-02T10:13:09.595298282
- id: "TUYATEC-deetibst/Motion"
deviceLabel: TUYATEC Motion Sensor
manufacturer: TUYATEC-deetibst
model: RH3040
deviceProfileName: motion-battery
Could you tell me if this device works with my driver? It is necessary to have the updated driver.
Thank you SO much, Mariano⦠seems to be working fine for me! Even reporting battery status (%). Do you have a link where I could make a contribution in appreciation of your efforts?
Iβm glad it works!
I have this link on my github, if you want to buy me a beer Iβll drink to your health!. ![]()
6 posts were split to a new topic: Zigbee network issues with Tuya devices
Hello, this is the model name of the pipe receiving valve, and itβs a finger printer, so please add it
Model: TS0601
Manufacturer Code: _TZE200_arge1ptm
I received the alarm today, set this up and it connected straight to Wesleyβs driver with no issues. The volume isnβt loud for a 90db sirenβ¦Many thanks for your quick response on this
