Hello Mariano,
Could you please add this one?
Itβs the Tuya water leak sensor 898EZ
Manufacturer: _TZ3000_upgcbody
Model: TS0207
Thanks,
Fran
Hello Mariano,
Model: TS0207
Thanks,
Fran
Already supported in @Mariano_Colmenarejo zigbee-moisture-sensor driver. You are welcome to try from Marianoβs channel
Apologies, I thought I had the driver installed.
2 posts were merged into an existing topic: Post Requests for Zwave Edge Drivers Here (community-created)
Hello @Mariano_Colmenarejo would you please be so kind and help again by adding following window curtain module with the βwindow-treatment-profile-calibβ profile?
QS-Zigbee-CP03
Manufacturer: _TZ3000_eg7awg6a
Model: TS130F
as well as:
Manufacturer Code _TZ3210_ol1uhvza
Model: TS130F
I can use it already with your zigbee window treatment driver Mc driver. But I donβt have all the setting options.
Thank you very much in advance,
Stephan
Hi @KochS
Added to this driver version with profile tuya calibration
You need uninstall old driver version from your hub and install this new version or wait to automatic driver updated in 12 hour maximum.
Unistall your device with app
Re-install device with this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Window Treatment Mc
Version 2024-06-19T11:44:46.301709867
- id: "TS130F/_TZ3000_eg7awg6a"
deviceLabel: TS130F Window Treatment
manufacturer: _TZ3000_eg7awg6a
model: TS130F
deviceProfileName: window-treatment-profile-calib
Good Morning @Mariano_Colmenarejo.
You are my hero!
It worked right away with Manufacturer Code _TZ3000_eg7awg6a.
With one little bug though:
As soon as it reaches the open 100%. The status shows open 100%. After 1 or 2 seconds, it shows closed 0% even though its open 100%.
Calibration, Motor Reverse or removing and adding multiple times didnβt show any change of behavior.
Unfortanetly Manufacturer Code _TZ3210_ol1uhvza doesnβt want to be joined with the window-treatment-profile-calib profile. I tried it multiple times but it always apears with the standard βwindow-treatment-profileβ profile.
Any thoughts?
_TZ3210_ol1uhvza is not in the fingerprints driver.
What model is it, TS130F?
Iβm sorry, but yes. I edited my original post after I posted it. Maybe thatβs why you couldnβt see it.
Sorry for the additional work.
Sorry, I didnβt see the edited text.
Added to this driver version.
You have to do the same as yesterday, uninstall the device and reinstall it with this version of the driver
I think that if you try to delete the driver with paired devices, it does not allow you to delete it, but it automatically updates to the latest version.
I also tried to correct the final status error of the other device
Version 2024-06-20T09:47:38.791632558
- id: "TS130F/_TZ3210_ol1uhvza"
manufacturer: _TZ3210_ol1uhvza
model: TS130F
_TZ3000_eg7awg6a is working perfect now. You are the best!
_TZ3210_ol1uhvza has a status issue, too. It works exactly how it supposed to. Except of the status.
Following behaviour:
If i press open, it opens. After reaching position open, it shows open 1-2 seconds. Than it closes for 1 second and shows partially open 1% (it doesnβt actually shut the blind, itβs still open).
If I press close, it shows close 1-2 seconds in the end position and opens up for one second (it doesnβt actually open the blind, itβs still closed) and shows status partially open 1%.
If enter 12% it shuts / opens as it should, but the status jumps to 1% after reaching desired position without actually doing anything.
One last think before I freak out with an other device. Is there any chance that you can get a MOES 2-Gang Dimmer zm-105b-m with your βZigbee Multi Switch and Child Mcβ Driver running?
Especially your option to switch from Momentary to Toggle switch, I know from your Z-Wave Driver, I miss sincerly!
Model: TS0601
Manufacturer Code: _TZE204_bxoo2swd
Thank you!!!
Fixed in this driver version
Version 2024-06-20T11:29:23.348273745
Sorry this device does not work with my driver.
It must work with personal-tuya-devices-generic-ef00 driver
I was afraid you might would say that. I was fighting with this driver already, but it isnβt as conveniant and fast as yours. Especially changing the type of switch drives me nuts. But I will figure it out! I will end up changing my physical toogle switches to momentary switches.
Thank you for everything! Enjoy your cold beverage later ;o)
You can buy a cheap tuya hub and pair it with the tuya smart app.
Configure the switch type in that app and then uninstall it without deleting the data and pair it with snartthings and it should keep the switch type configuration.
I will take it to your health! thank you
Yes, I know. @Paul_Oliver mentioned it to me already in this thread: [ST Edge] Personal Tuya Devices - Generic EF00 Device - #945 by Paul_Oliver
But I was hoping I could get arround this, since Iβm a cheap and lazy German ;o)
Thanks again for everything to everybody!
You could try with a Lidl hub, configure the dimmer a change it by a beer box ![]()
Hi Mariano,
Iβve come across a fairly new Zigbee CO sensor, from MOES,
β¦ which looks a lot like a recently introduced Heiman,
Hereβs what your βZigbee Thing Mcβ driver gave me (raw data, the presentation in the SmartThings app did not render). Any chance you could please add this to the smoke/CO driver? Many thanks!
| Manufacturer: _TZE200_rjxqso4a Model: TS0601 FingerPrinted_EndPoint.Id: 0x01 App Version: 0x48 ZCL Version: 0x03 Network ID: 0x0223 Zigbee EUI: A4C13831CE56193B Device ID: 3134d63e-8835-4049-bec0-88ff81c3793e Server Cluster: Ep: 0x01={ 0004,0005,EF00,0000 } Client Clusters: Ep: 0x01={ 0019,000A } Signal Metrics: LQI: 208 .... RSSI: -71 dbm |
Hi Peter,
Sorry, This device uses tuya cluster EF00 and does not work with my driver.
Could works with personal tya EF00 driver
Will try, thanks for the pointer.
