This is the invitation link to the channel:
https://api.smartthings.com/invitation-web/accept?id=6b68563b-1905-4654-8d2b-e677a2997424
Many thanks @TapioX . Iβm still very green to this.
Much appreciated
First thank you for your contribution of your drivers.
I am looking to add a powerstrip from Namron. As of now I can only use it as a normal switch and control only one of the outlets. Iβm not sure what kind of info you need from this unit?
Attached a screenshot.
Hi @Peter_swe
Install zigbee thing Mc from my Channel and switch to that driver.
The necessary data on how many endpoints and which clusters it uses will appear in the history.
Data may take up to 30 minutes to appear in history due to an error in smartthings
Aded to this driver version
You need install this driver version
uninstall device and reinstall device
You do not perform a driver change
may take up to 30 minutes to can pair your device with this drivery due to an error in smartthings
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2024-04-27T11:42:55.390092392
- id: "4512735/NAMRON"
deviceLabel: NAMRON Five Plugs
manufacturer: NAMRON AS
model: 4512735
deviceProfileName: five-outlet
Many thanks for your help! Works perfect!
Hi! @Mariano_Colmenarejo Iβm trying to get the Schneider Wiser PIR motion sensor + dimmer combo to work in Smart Things. Would it be possible with your drivers?
Here are the device details:
Manufacturer: Schneider Electric
Model: NHMOTION/DIMMER/1
FingerPrinted_EndPoint.Id: 0x03
App Version: 0x02
ZCL Version: 0x03
Network ID: 0x59C2
Zigbee EUI: 50325FFFFE4FF99D
Device ID: bc6f21ed-5365-4ba1-b69f-f6563301c21a
Server Cluster: Ep: 0x25={ 0000,0003,0400,0406,0B05,FF19 }Ep: 0x03={ 0000,0003,0004,0005,0006,0008,0301, 0B05 }
Client Clusters: Ep: 0xF2={ 0021 }Ep: 0x25={ 0003,0006,0008,0406 }Ep: 0x03={ 0019 }
Signal Metrics: LQI: 166 β¦ RSSI: -91 dbm
Hello @Mariano_Colmenarejo - I bought a Door/Window sensor from Moes.
Could you please check if you can add it?
Hi @Fra201
I donβt have any controller that combines a dimmer with a motion sensor.
It would be necessary to create it from scratch and without having the device to debug it it is complicated.
Now Iβm very busy with other things and I donβt know if I will have time to do it.
I will take note, but I donβt guarantee anything
Added to this driver version
Name Zigbee Contact Mc
Version 2024-05-05T18:50:42.62682673
- id: "_TZ3000_gntwytxo/Close Sensor"
deviceLabel: TS0203 Close Sensor
manufacturer: _TZ3000_gntwytxo
model: TS0203
deviceProfileName: contact-battery-profile
Hello, could you please help me adding it.to your driver?
Its a scene switcher I found on aliexpres
Tuya ZigBee Button Scene Switch Intelligent Linkage Smart Switch Battery Powered Automation
This is the link
https://a.aliexpress.com/_EQUDTbv
@Mariano_Colmenarejo is not developing driver for scene switches.
This device should work with @zambobmaz driver. Try his channel from here:
https://bestow-regional.api.smartthings.com/invite/RBlE1zVbOQlE
Can you please add:
model: TS0207
manufacturer: _TZ3000_mugyhz0q
You can label it as TuYa 899WZ if you want
This is the same as:
manufacturer: _TZ3000_k4ej3ww2
model: TS0207
which you already added
You need install this driver version in your hub
Name Zigbee Moisture Sensor Mc
Version 2024-05-15T17:13:05.439339763
- id: "_TZ3000_mugyhz0q/TS0207"
deviceLabel: TuYa 899WZ Water Sensor
model: TS0207
deviceProfileName: moisture-battery
_TZ3000_mugyhz0q
Confirm works⦠As usual thank you for your work ![]()
Hi,
Try it if works
Name Zigbee Motion Sensor Mc
Version 2024-05-15T21:05:56.185746676
- id: "_TZE200_kb5noeto/TS0601"
deviceLabel: SP2-ZB Motion Sensor
manufacturer: _TZE200_kb5noeto
model: TS0601
deviceProfileName: motion-illuminance
Works like a charm, thanks for the quick response!
A better label description will ZG-204ZM PIR 24Ghz human presence sensor you can change it if you like. I donβt think that the 24GHz section is used in your driver since it using DPβs. Only the PIR Motion and Illuminance are available.
