(EDGE Driver-Mc): Zigbee Drivers for Motion, Open/Close, Moisture, Smoke-Co Sensors and others Devices
Hey there! I am using an Ikea motion sensor (the E1745) and just can’t get it to work.
It doesn’t work with the standard driver so i tried this one and still, it always get’s stuck on “Motion detected” and never recovers.
Has anyone any idea how to fix this? It’s driving me crazy :slight_smile:
i am using an Aeotec Hub V3.
Runs with Zigbee Motion Sensor Mc by @Mariano_Colmenarejo .
This sensor does however tend to show very often offline, although it then responds on movement.
Better to delete and re-pair to make it configure correctly.
thanks, but that’s what i am using, the MC driver, still, it just gets stuck on “motion detected”
Have you tried deleting the deleting the sensor and then repairing, not changing driver from the stock driver? I comment as I really find it works really well, albeit with the caveat of often showing offline.
i tried everything, it always goes to “motion detected” even if there is none and then stays like that indefinitly
Hi @drac
Sorry, I don’t have any of these devices to help you.
If it doesn’t work with the stock driver either, it may be broken, right?
You can open a ticket in smartthings as it is supported by the stock driver and it must be work
Thank you!
I want to add Bosch zigbee contact sensor (contact, vibrations, button) to edge drivers please.
BOSCH Door/window contact II plus
BSEN-CV
Functions could be added that are executed with clusters and standard attributes, such as open/close or temperature.
If it uses a cluster and custom attributes for the vibration, it cannot be added without knowing how it works.
Ok, what should I do about it?
Pair it with the zigbee thing Mc driver to see the fingerprints and clusters the device uses
Unfortunately, smartthings hub with Thing MC driver cannot find the sensor. I will keep trying.
Hi.
I bought a new SONOFF Zigbee Thermostatic Radiator Valve a few days ago.
Can you please add it?
I would appreciate your quick help.
Greetings.
Hi @The_John_Carter
It is not as easy as adding the fingerprints to the driver.
Thermostats are devices that have very different functions in each manufacturer and the documentation of this device is practically non-existent, to know what modes, attributes and values it uses.
I will try to find some information on other platforms or if you find it, send it to me and when I have time I will try to do something
Thanks for your reply. If I find any information I will send it to you.
Regards
Hi Mariano
Can you please add following
Thank you in advance
Hi @Mariano_Colmenarejo
I’m writing for a couple problem on a multi switch device :
DRIVER_ID: “e9bfd289-1d51-499e-8c64-d564d1868ad2”
deviceManufacturerCode: “_TZ3000_cfnprab5”
This multi switch is with one group of USB ports(2) and 4 outlets.
With your drivers I can see Switch 2,3,4,5 that are respectively :
2 → Outlet number 2
3 → Outlet number 3
4 → Outlet number 4
5 → Usb group
and
“All Switch On-Off” option that I can use correctly to power up and down all outlets
So there is the first Switch missing.
Now the behavior is this:
If I power up the multi switch from the main power button in smart things App, device is powering up always with the Outlet port 1 switched on, and I cannot switch it off because I cannot manage it from the app.
Second Issue I found is that if I switch the power off from the main button in the app, and there is outlet 2,3,4,5 powered on, the device is not powering down even if it seems so in Smartthings app.
Can you fix it ?
Thank you very much in advance . In Attach some logs I have collected.
General On
2023-11-12T11:02:21.421695871+00:00 DEBUG Zigbee Multi Switch and Child Mc driver device thread event handled
2023-11-12T11:02:26.734992205+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler capability
2023-11-12T11:02:26.775306538+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received command: {“command”:“on”,“component”:“main”,“positional_args”:{},“capability”:“switch”,“args”:{}}
2023-11-12T11:02:26.788848538+00:00 TRACE Zigbee Multi Switch and Child Mc Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:02:26.791212205+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:26.894343871+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-11-12T11:02:26.903324205+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5049, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC6, rssi: -62, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x97, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2023-11-12T11:02:26.925942871+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-11-12T11:02:26.927217205+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5049, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xD0, rssi: -62, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x03, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-11-12T11:02:26.934800871+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:02:26.946830871+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-11-12T11:02:26.948787205+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“visibility”:{“displayed”:false},“capability_id”:“legendabsolute60149.signalMetrics”,“attribute_id”:“signalMetrics”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/11/12 Time: 11:02
DNI: 0x5049 LQI: 198 RSSI: -62dbm
2023-11-12T11:02:26.959455871+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“switch”,“attribute_id”:“switch”,“state”:{“value”:“on”}}
2023-11-12T11:02:26.984668205+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:26.997974205+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:02:27.003234871+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2023-11-12T11:02:27.005793538+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“switch”,“attribute_id”:“switch”,“state”:{“value”:“on”}}
2023-11-12T11:02:27.024916871+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:27.026207538+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:27.030850871+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:29.003993205+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“attribute_id”:“switchAllOnOff”,“state”:{“value”:"S1:On "}}
2023-11-12T11:02:29.015370538+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:29.089622538+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“attribute_id”:“switchAllOnOff”,“state”:{“value”:"S1:On "}}
2023-11-12T11:02:29.098579872+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:51.430767208+00:00 DEBUG Zigbee Multi Switch and Child Mc driver device thread event handled
On Switch2
2023-11-12T11:02:57.354982542+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler capability
2023-11-12T11:02:57.381996875+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb
[0x5049] (multipresa stampanti 3D)> received command: {“command”:“on”,“component”:“switch2”,“positional_args”:{},“capability”:“switch”,“args”:{}}
2023-11-12T11:02:57.384203875+00:00 TRACE Zigbee Multi Switch and Child Mc Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:02:57.385430542+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:57.485636208+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-11-12T11:02:57.488713875+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5049, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xD0, rssi: -63, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x99, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2023-11-12T11:02:57.492810208+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-11-12T11:02:57.498356208+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5049, src_endpoint: 0x02, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xD0, rssi: -66, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x04, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-11-12T11:02:57.525748208+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:02:57.527016875+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-11-12T11:02:57.530365542+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“visibility”:{“displayed”:false},“capability_id”:“legendabsolute60149.signalMetrics”,“attribute_id”:“signalMetrics”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/11/12 Time: 11:02
DNI: 0x5049 LQI: 208 RSSI: -63dbm
2023-11-12T11:02:57.584511208+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“switch2”,“capability_id”:“switch”,“attribute_id”:“switch”,“state”:{“value”:“on”}}
2023-11-12T11:02:57.684755875+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:57.759297208+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:02:57.783961875+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2023-11-12T11:02:57.793808875+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“switch2”,“capability_id”:“switch”,“attribute_id”:“switch”,“state”:{“value”:“on”}}
2023-11-12T11:02:57.869665542+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:57.895712542+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:57.931826542+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:59.681541209+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“attribute_id”:“switchAllOnOff”,“state”:{“value”:"S1:On S2:On "}}
2023-11-12T11:02:59.693096209+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:02:59.880641875+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“attribute_id”:“switchAllOnOff”,“state”:{“value”:"S1:On S2:On "}}
2023-11-12T11:02:59.888761875+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
On Switch5
2023-11-12T11:03:53.555303794+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler capability
2023-11-12T11:03:53.664945461+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received command: {“command”:“on”,“component”:“switch5”,“positional_args”:{},“capability”:“switch”,“args”:{}}
2023-11-12T11:03:53.687561128+00:00 TRACE Zigbee Multi Switch and Child Mc Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:03:53.731560794+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:03:53.857636128+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-11-12T11:03:53.873999128+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5049, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC8, rssi: -62, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x9F, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2023-11-12T11:03:53.901357128+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-11-12T11:03:53.915317794+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5049, src_endpoint: 0x05, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCE, rssi: -62, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x07, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-11-12T11:03:53.950151461+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:03:53.962375461+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-11-12T11:03:53.966123794+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“visibility”:{“displayed”:false},“capability_id”:“legendabsolute60149.signalMetrics”,“attribute_id”:“signalMetrics”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/11/12 Time: 11:03
DNI: 0x5049 LQI: 200 RSSI: -62dbm
2023-11-12T11:03:53.994558128+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“switch5”,“capability_id”:“switch”,“attribute_id”:“switch”,“state”:{“value”:“on”}}
2023-11-12T11:03:54.034576794+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:03:54.039663461+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:03:54.040884461+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2023-11-12T11:03:54.047159794+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“switch5”,“capability_id”:“switch”,“attribute_id”:“switch”,“state”:{“value”:“on”}}
2023-11-12T11:03:54.076915794+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:03:54.079648794+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:03:54.092152794+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:03:56.032611461+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“attribute_id”:“switchAllOnOff”,“state”:{“value”:“All On”}}
2023-11-12T11:03:56.044184795+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:03:56.089948128+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“attribute_id”:“switchAllOnOff”,“state”:{“value”:“All On”}}
2023-11-12T11:03:56.115789795+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:04:21.434655131+00:00 DEBUG Zigbee Multi Switch and Child Mc driver device thread event handled
Generic Off
2023-11-12T11:04:25.304587798+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler capability
2023-11-12T11:04:25.333245798+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received command: {“command”:“off”,“component”:“main”,“positional_args”:{},“capability”:“switch”,“args”:{}}
2023-11-12T11:04:25.347376131+00:00 TRACE Zigbee Multi Switch and Child Mc Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:04:25.348625131+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:04:25.454013798+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-11-12T11:04:25.460726465+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5049, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCE, rssi: -61, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xA1, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: false > > > >
2023-11-12T11:04:25.484618798+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-11-12T11:04:25.485905465+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5049, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCC, rssi: -63, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x09, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x00, ZclStatus: SUCCESS > > >
2023-11-12T11:04:25.493684465+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:04:25.504722465+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-11-12T11:04:25.506723798+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“visibility”:{“displayed”:false},“capability_id”:“legendabsolute60149.signalMetrics”,“attribute_id”:“signalMetrics”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/11/12 Time: 11:04
DNI: 0x5049 LQI: 206 RSSI: -61dbm
2023-11-12T11:04:25.516236465+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“switch”,“attribute_id”:“switch”,“state”:{“value”:“off”}}
2023-11-12T11:04:25.545546131+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:04:25.551129798+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:04:25.561394131+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2023-11-12T11:04:25.563767465+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“switch”,“attribute_id”:“switch”,“state”:{“value”:“off”}}
2023-11-12T11:04:25.605239465+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:04:25.606536465+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:04:25.611032465+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:04:27.560458798+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“attribute_id”:“switchAllOnOff”,“state”:{“value”:"S2:On S3:On S4:On S5:On "}}
2023-11-12T11:04:27.570439465+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:04:27.615090465+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“attribute_id”:“switchAllOnOff”,“state”:{“value”:"S2:On S3:On S4:On S5:On "}}
2023-11-12T11:04:27.623289465+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:04:51.444667135+00:00 DEBUG Zigbee Multi Switch and Child Mc driver device thread event handled
Generic On
2023-11-12T11:05:01.146459136+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler capability
2023-11-12T11:05:01.149433469+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received command: {“command”:“on”,“component”:“main”,“positional_args”:{},“capability”:“switch”,“args”:{}}
2023-11-12T11:05:01.151351802+00:00 TRACE Zigbee Multi Switch and Child Mc Found CapabilityCommandDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:05:01.177067469+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:05:01.264983802+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-11-12T11:05:01.271943469+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5049, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCE, rssi: -61, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0xA3, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2023-11-12T11:05:01.295897136+00:00 TRACE Zigbee Multi Switch and Child Mc Received event with handler zigbee
2023-11-12T11:05:01.297191136+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x5049, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCE, rssi: -61, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0A, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x01, ZclStatus: SUCCESS > > >
2023-11-12T11:05:01.307345469+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:05:01.319166802+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2023-11-12T11:05:01.321160802+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“visibility”:{“displayed”:false},“capability_id”:“legendabsolute60149.signalMetrics”,“attribute_id”:“signalMetrics”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2023/11/12 Time: 11:05
2023-11-12T11:05:01.332009136+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“switch”,“attribute_id”:“switch”,“state”:{“value”:“on”}}
2023-11-12T11:05:01.363062802+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:05:01.368311802+00:00 TRACE Zigbee Multi Switch and Child Mc Found ZigbeeMessageDispatcher handler in Zigbee_Multi_Switch
2023-11-12T11:05:01.369555802+00:00 INFO Zigbee Multi Switch and Child Mc Executing ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
2023-11-12T11:05:01.375279469+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“switch”,“attribute_id”:“switch”,“state”:{“value”:“on”}}
2023-11-12T11:05:01.392283802+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:05:01.400557469+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:05:01.404557469+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:05:03.485385469+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“attribute_id”:“switchAllOnOff”,“state”:{“value”:“All On”}}
2023-11-12T11:05:03.514980469+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:05:03.601992469+00:00 INFO Zigbee Multi Switch and Child Mc <ZigbeeDevice: de65cbff-f8fd-4f66-bbf5-5832f346fafb [0x5049] (multipresa stampanti 3D)> emitting event: {“component_id”:“main”,“capability_id”:“legendabsolute60149.switchAllOnOff1”,“attribute_id”:“switchAllOnOff”,“state”:{“value”:“All On”}}
2023-11-12T11:05:03.643793136+00:00 DEBUG Zigbee Multi Switch and Child Mc multipresa stampanti 3D device thread event handled
2023-11-12T11:05:21.441632471+00:00 DEBUG Zigbee Multi Switch and Child Mc driver device thread event handled
Hi @simoc
The main switch in the App corresponds to switch-1 on the device.
The main switch only turns physical switch 1 on and off and shows the status of switch-1 when you physically turn it on or off.
To turn all the switches on or off at the same time there is the All switch On-Off switch.
Hi @lalooprasad
Sorry, I have no idea how this device works.
Hi @The_John_Carter
I have not found much information about the TRV sonoff thermostat.
For example, it seems to use the Off, Heat and Auto modes, I don’t know if Auto is true and how it works.
I have not found what the On/Off cluster (0006) is used for either.
Try it and if you see that something doesn’t work, send me logs with the CLI of the function that doesn’t work.
You have to uninstall it and pair it again directly with this TEST driver.
 Name         Zigbee Thermostat Mc-TEST
 Version      2023-11-12T17:37:07.116020809
- id: "SONOFF/TRVZB"
    deviceLabel: SONOFF Thermostat
    manufacturer: SONOFF
    model: TRVZB
    deviceProfileName: thermostat-sonoff
