Read here, @RBoy may have driver to this keypad (not free):
Hello.
I paired the device with Smartthings and now it is recognized correctly ![]()
Great job!
I haven’t tested it 100% yet, but so far the basic functions work fine.
“Auto mode” does not work - I get the message “A network or server error has occurred. Please try again later.”
I suppose “Auto mode” is responsible for setting schedules. At what times and days the heating should turn on or off to the set temperatures.
The tile shows information:
When the thermostat is heating there is a yellow icon and it says “heating”
When the thermostat has heated above the set temperature the icon is grey and shows “idle”
In my opinion it looks good but you could also add information about “current temperature” or “set temperature” or even both. Then the tile would be more functional.
It would also be nice to add a temperature change interval of 0.5 degrees, the thermostat knob changes the temperature by 0.5 degrees and the smartthings app by 1 degree.
If possible, of course.
I would be very grateful.
Best regards!
Hi
This version of the driver shows the current temperature on the mosaic and the set point adjustment steps are 0.5ºc.
Install this new version from my channel and try to see if auto mode works now
Name Zigbee Thermostat Mc-TEST
Version 2023-11-12T22:01:41.263339887
Hi
“Auto mode” does not work.
“Current temperature” is already displayed and the temperature change interval is 0.5 degrees
Great ![]()
But the icon is yellow all the time, it no longer shows the “heating” or “idle” status.
Is it possible to combine the display of temperature and heating or idle status on the mosaic?
Or at least that the icon would be yellow if there is a heating state and gray when there is an idle state?
Hi,
The icon changes from active to inactive with the value set in the corresponding capability.
If the temperature is seen then the icon is always in active mode since there are no defined values for active and inactive.
In a simple tile only one capability value can be displayed.
I have created an optional profile to display a multiple tile.
From preference settings you can choose the multiple Tile profile that shows 5 capabilities, default value is single tile:
- OperatingState
- Temperature
- HeatingSetPoint
- ThermostatMode
- Battery
When the new profile is selected and displayed, you have to close the app, clear the cache and reopen the app.
I have removed Auto mode as it should not work on the device.
Version 2023-11-13T14:16:20.516159574
Hi.
Thanks for the information. Really great work!
I have one more question. Can you add the possibility to set a “temperature correction” with an interval of 0.1 degrees?
It would be nice to be able to correct the temperature on the thermostat if it is different from the room temperature.
Best regards.
Hi,
A temperature correction could be added, but that correction would only be for the purpose of correcting the value shown in the app since the temperature attribute is only read on the thermostat and the calculations it makes to open or close the radiator valve are made with the temperature that the thermostat has internally without correcting.
Please, could you post a screenshot of the multiple mosaic of the thermostat to see how the information turned out?
Looks like an attractive TRV purchase option!
I also think it is worth paying attention to this thermostat ![]()
I noticed that when you removed the “auto mode” the option to select a second mode “Off mode” also disappeared.
Before removing “Auto mode”
After removing “Auto mode”
Could you please restore the option to select between “Off mode” and “Heating” ?
If it is not possible to restore only “Off mode” then restore also “Auto mode”. I will simply use the two modes “Heating” and “Off mode” and “Auto mode” will not be used.
“Off mode” I want to use for creating procedures, so this would be useful.
And here is the look of the tile with all the information ![]()
Status “heating”
Status “idle”
Only remove Auto mode.
It should work the same.
Try Performing a driver change to zigbee Thing Mc, for example, and change to this driver again so that the supported modes are established in the init lifecycle.
The possibility to select “Off mode” returned after applying your tips.
I am really grateful to you for your great work.
Best regards.
I’m glad it works well.
I have published the final version in the Mc driver
Install this driver Mc on your Hub and perform a driver change. Then remove the TEST version from your Hub
I will need the TEST version for another user’s device and I will make modifications to it.
Please let me know when you have upgraded to the final version.
Version 2023-11-13T20:18:26.142469486
I installed the correct version of the driver and removed the test version.
Thank you very much.
thanks. I have been following that thread. its not converted to edge yet.
Sorry, this is only basic user information, it does not contain any technical information that allows to know how it works.
In any case, as I have already told other users, I do not plan to make drivers for zigbee multi-buttons. I don’t know how they work and I already have enough tasks in my backpack at this point.
No worries. Thank you for your time.
Hi Im trying to add devices " Samotech door sensor" SM300Z.
its adding it as a “zigbee thing” and rejects “zigbee contact mc” driver if i try to reassign.
can you help?
Hi @dillans147
Open the my.smartthings.com website and enter advanced users.
In the devices menu find your device and open the details.
Find and publish the model and manufacturer code.
You can also install my zigbee thing Mc driver and make a driver change. Publish the displayed device data to the app
Manufacturer Code: _TZ3000_bnai1qnw
Model: TS0203
Ive updated the driver to “zigbee thing Mc” not sure what is meant by
“Publish the displayed device data to the app”
Take a screenshot(s) where is possible to see
manufacturer:
model:
Server Cluster:
Client Cluster:
and publish screenshot(s)
