Youβll have to join @Mariano_Colmenarejo channel in here:
and add the following driver:
Zigbee Contact Mc
Zigbee Contact Mc
I take note to do it in the month of August, until then I do not have access to the CLI or a pc
Hello,
I have two switch models with energy monitor, which work well with this driver, they measure the instantaneous consumption and the energy consumed.
My question is if anyone knows why these devices do not appear in the energy section of the application.
They seem to be compatible equipment
Thank you.
For the most part the Energy Section of the app only works with Samsung appliances.
Hi @Raimundo
No problem!
IIβll wait. good vacation
Hi @yehudaasa
Hi Mariano.
Can you please add support for the somgoms 4 gang switch?
It shows 1 ep but it is a 4 gang switch.
@Mariano_Colmenarejo ,
Can you please help @Itamar_Talmi see post above. He is a good friend and didnβt tag you rightβ¦
Sorry, I did not take note.
Added to this driver version
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2023-07-31T19:28:22.434203156
- id: "_TZ3000_99sdxhlg/TS0004"
deviceLabel: TS0004 Switch
manufacturer: _TZ3000_99sdxhlg
model: TS0004
deviceProfileName: four-switch
Hi @solidwater922 @Gonzo @KleverBatista @lmd569 @laniocarvalho @nexus
Your devices were added to this driver version
Name Zigbee Contact Mc
Version 2023-07-31T19:42:21.894001545
- id: "TUYATEC-ydcwf5m2/RH3001"
deviceLabel: RH3001 Open/Close Sensor
manufacturer: TUYATEC-ydcwf5m2
model: RH3001
deviceProfileName: contact-battery-profile
- id: "Orvibo/Contact Sensor"
deviceLabel: Orvibo Open/Close Sensor
manufacturer: 欧η
model: 75a4bfe8ef9c4350830a25d13e3ab068
- id: "feibit/FNB56-DOS07FB3.0"
deviceLabel: feibit Open/Close Sensor
manufacturer: feibit
model: FNB56-DOS07FB3.0
- id: "_TZ3000_yfekcy3n/Contact Sensor"
deviceLabel: TS0203 Contact Sensor
manufacturer: _TZ3000_yfekcy3n
model: TS0203
- id: "_TZ3000_6zvw8ham/Contact Sensor"
manufacturer: _TZ3000_6zvw8ham
model: TS0203
Hi @AllanLee @Thorsten_Joachims
Name Zigbee Moisture Sensor Mc
Version 2023-07-31T20:33:35.750781115
- id: "_TYZB01_o63ssaah-Sensor"
deviceLabel: TS0207 Water Sensor
manufacturer: _TYZB01_o63ssaah
model: TS0207
deviceProfileName: moisture-battery
- id: "_TZ3000_4uvovz4r/Sensor"
manufacturer: _TZ3000_4uvovz4r
model: TS0207
Thanks for all @Mariano_Colmenarejo
Hi @silencer22
Name Zigbee Motion Sensor Mc
Version 2023-07-31T20:44:54.893322932
- id: "_TYZB01_vwqnz1sn/Motion"
deviceLabel: TS0210 Motion Sensor
manufacturer: _TYZB01_vwqnz1sn
model: TS0202
deviceProfileName: motion-illuminance
Top man - now working perfectly thank you!!
It works. Thank you so much.
2023λ 8μ 1μΌ (ν) μ€μ 5:47, Mariano Colmenarejo via SmartThings Community <notifications@smartthings.discoursemail.com>λμ΄ μμ±:
Hi @baivab
Added to this driver version as Gas detector.
Is the first device that uses defaults for gasDetector capability with status proposed.
I do not know if it will work
Name Z-Wave Smoke Alarm-Mc
Version 2023-08-01T20:17:44.641751871
- id: 0260/8003/1000
deviceLabel: Heiman HS1CG Gas
manufacturerId: 0x0260
productType: 0x8002
productId: 0x1000
deviceProfileName: gas-battery
