(EDGE Driver-Mc): Z-Wave Edge Drivers and others with FIBARO devices:
@S.F.B @omergranot88
I am going to correct the code and if it works well you should notify smartthing so they can fix the stock driver
@S.F.B @omergranot88 update
Modified in this driver version:
  • Switch binary report
  • Meter report for Energy and power events
  • Central scene notification for S1 scenes to button, but not will work for button1, S1 and Button2, S2 scenes it not will work due to profile need add a button1 and button2 components, missing
In preferences you can configure S1 and S2 send scenes but it not will works until button1 and button2 added to profile.
I can’t debug this profile change and therefore I leave it without fixing
Need this profile modification
You can install immediately this driver version with CLI with command:
smartthings edge:drivers:install
 Name         Z-Wave Switch and Child Mc
 Version      2023-04-03T19:58:02.016897363
Hi @omergranot88
Did it work with this version?
Hi @Mariano_Colmenarejo
Sorry for the delay but i had no time before.
For me i need an edge driver button because is more like the keyfob but with only 2 buttons.
however when I look at the devices compatible with the button edge drivers I see the fibaro button and the keyfob but not the fibaro walli controler.
can you add it in your edge drivers or i have not yet understood how smartthings works
Thank you
Just wanted to say thank you for the Smart Implant driver, Mariano. My gate is now working again!
New version of Z-Wave Switch and Child Mc:
  • Added to profile of Fibaro single switch FGS- 213, button1 and button2 components.
  • Modified code to execute scenes, sending events to button1 for S1 scenes and to button2 for S2 scenes if are activated wit parameters 28 or/and 29
 Version      2023-04-06T11:23:43.217297079
First of all, thank you Mariano for the Fibaro Smart Implant (FSI) driver. I can finally see the value of the onboard temperature sensor.
I still have one issue. I have two DS18B20 temperature sensors connected to the FSI but I can only get a temperature reading from one of them. When I connect each one individually they each work correctly so I believe the sensors and wiring are correct. When I connect them at the same time to the FSI the driver reports β€œ- β€˜C” for the second one.
I’ve also tried to get it to work with and without the 4.7K ohm pull-up resistor on the serial line. There is no change in the behavior.
In order to try and get the driver to recalculate what temperature sensors were attached I went into Settings and checked β€œ6 External Temp Probe”. The log file output at this point is here.
Has anyone been able to get more than DS18B20 temperature sensor to work? If so, could you please give me any ideas on what else I can try. Thanks.
I have two sensors working for several weeks using Smart Implant Beta-4 driver. Try remove Smart Implant and then rejoin Smart Implant when both sensors are connected.
@TapioX, thank you for the suggestion. I removed and reinstalled the device again this morning and, unfortunately, only one external temperature probe is providing a reading.
Do you use a pull-up resistor in your configuration?
I’m not using pull-up resistor.
Both sensors are connected using 1 meter cable.
Can you please add the following parameters to
Fibaro Roller Shutter 3
24
  1. Inputs orientation
This parameter allows reversing the operation of switches connected to S1 and S2 without changing the wiring.
Available settings:
0 – default (S1 – 1st channel, S2 – 2nd channel)
1 – reversed (S1 – 2nd channel, S2 – 1st channel)
Default setting: 0
Parameter size: 1 [byte]
And also
25
  1. Outputs orientation
This parameter allows reversing the operation of Q1 and Q2 without changing the wiring (in case of invalid motor connection) to ensure proper operation.
Available settings:
0 – default (Q1 – 1st channel, Q2 – 2nd channel)
1 – reversed (Q1 – 2nd channel, Q2 – 1st channel)
Default setting: 0
Hi Mariano
Would it be possible to use this to make the child device(Edge_child) display the power and energy?
Is it possible to make the child device display the energy and power?
I integrate Smartthings with Home Assistant and use the energy and power there.
HI @dotan_shai
This is done a long time ago
HI @Ped
Sorry, this requires modifying and adding quite a few things to the driver.
I don’t know if in the future I will have time to do it, right now I don’t have it.
The stock Zwave Switch driver has it done
Thanks, appreciate the reply.
Can’t seem to get my Fibaro devices to work properly with the stock drivers.
Your drivers have been a life saver.
Thanks again
This pictures sent from a friend of mine:
Looks like the reverse polarity is missing… Can you please check
This profile in your screenshot is for a qubino-flush-shutter, is not for fibaro roller shutter 3
- id: QubinoFlushShutter/AC
    deviceLabel: Qubino Window Treatment
    manufacturerId: 0x0159
    productType: 0x0003
    productId: 0x0052
    deviceProfileName: qubino-flush-shutter
  - id: QubinoFlushShutter/DC
    productType: 0x0003
    productId: 0x0053
components:
- id: main
  capabilities:
  - id: windowShade
    version: 1
  - id: windowShadeLevel
    version: 1
  - id: windowShadePreset
    version: 1
  - id: powerMeter
    version: 1
  - id: energyMeter
    version: 1
  categories:
  - name: Blind
preferences:
  - name: "operatingModes"
    title: "Operating Modes"
    description: "Set the device's operating mode."
    preferenceType: enumeration
    required: true
    definition:
      options:
        0: "Shutter mode"
        1: "Venetian mode"
      default: 0
  - name: "slatsTurnTime"
    title: "Slats turn time"
    description: "Specify the time required to rotate the slats 180 degrees. (100 = 1 second)"
    required: true
    preferenceType: integer
    definition:
      minimum: 0
      maximum: 32767
      default: 150
  - name: "slatsPosition"
    title: "Slats position"
    description: "Configuration defines slats return to previously set position after up/down
    movement through Z-wave or push-buttons."
    required: true
    definition:
      options:
        0: "In case of Z-wave control"
        1: "Manual operation or limit is reached"
      default: 0
  - name: "motorUpDownTime"
    title: "Motor up down time"
    description: "Set the amount of time it takes to completely open or close shutter.
    Check manual for more detailed guidance."
    required: true
    definition:
      minimum: 0
      maximum: 32767
      default: 0
  - name: "motorOperationDetection"
    title: "Motor operation detection"
    description: "Power usage threshold which will be interpreted as motor reaching the limit switch."
    required: true
    definition:
      minimum: 0
      maximum: 127
      default: 30
  - name: "forcedCalibration"
    title: "Forced calibration"
    description: "After selection '1' option, shutter enters the calibration mode.
    When it is finished, completing full cycle - up, down and up, set this parameter value back to first option."
    required: true
    definition:
      options:
        0: "Calibration finished or not started"
        1: "Start calibration process"
      default: 0
My friend confirm that you were right. He forgot that he is using Qubino module. NOT Fibaro…
As usual thanks for helping
Sorry, I forgot to reply to you.
You have to activate in preferences send scenes, parameter 28 for S1 and parameter 29 for S2 to value 15, which sends all possible actions
When you perform the actions on the ficisco switch, you have to see in the details view that Button-1 shows the scenes for S1 and Button-2 shows the scenes for S2.
The routines are made by putting in the IF part the actions of button-1 or button-2
Thank you. After Smarthings broke their Z-Wave Switch Driver, I was able to use this to get this dual outdoor switch working again.
