The new driver is throwing errors
2023-02-05T03:39:16.368738009+00:00 ERROR Fibaro Smart Implant BETA Fibaro Smart Implant thread encountered error: [string “st/dispatcher.lua”]:233: Error encountered while processing event for <ZwaveDevice: 90395e70-07a9-4915-a570-941b5930c937 [42] (Fibaro Smart Implant)>:
> arg1: {args={precision=1, scale=“CELSIUS”, sensor_type=“TEMPERATURE”, sensor_value=32.7, size=2}, cmd_class=“SENSOR_MULTILEVEL”, cmd_id=“REPORT”, dst_channels={0}, encap=“NONE”, payload=“\x01\x22\x01\x47”, src_channel=7, version=1}
> [string “init.lua”]:124: attempt to perform arithmetic on a nil value (field ‘internalTempOffset’)
And now it is no longer working at all…
I’m guessing this is because the value of “internalTempOffset” and “externalTenpOffset” are 0 which is a correct default… but probably not handled as a special case …
Please advise
Out of curiosity - is it possible to select an older driver version or does the infrastructure only support use of the latest ?
