[Edge] Driver for Aqara Switches and Remotes
Thank you so much for pointing me. Somehow, I am not so familiar and I did not manage to get it to work.
Great job with these @veonua
I’ve been setting my Aqara cube which is so much easier from a single tile, without need to go create a bunch of core pistons.
I have a question though, as the cube does not run any automations on “Tap” and it does not show up in the history either. What is the actual physical function to activate this? So far I’ve tried single, double, and many taps to the face up side.
it’s more like knock , i should rename it.
Hi @veonua
If I may ask, is there support for the following no-neutral aqara wall switches?
QBKG21LM
QBKG22LM
QBKG25LM
I have all 3 installed in my home and using legacy DTL handlers but would be glad to switch to edge drivers and help test them.
@veonua awesome job with these drivers. Work perfect. I apologize if I didn’t see this question or response in the thread, I’m using the Aqara Opple 6 button with your driver and it works great. Any chance you can add the 4 button Aqara Opple model (WXCJKG12LM) to the driver? Everytime I try to add it to ST, it doesn’t pick up your Aqara Button driver but it’s picked up as a Zigbee Thing and I can’t change the Driver. Weird thing is that it controls all my Zigbee bulbs and plugs even when not set up… Thanx in advance
all of them are supported, please check
@veonua
I have quite a number of xiaomi devices
Things that are working using your edge driver
Xiaomi motion sensor
Xiaomi button
Have problem pairing
Aqara switch single button WXKG03LM rev 1(it did appear once but not working then can’t be paired so far)
I have one problem for now which is i cant select xiaomi motion sensor in SHM but the device itself is working completely fine except problem with displaying the battery level (i got such problem with my IKEA 5 buttons remote stock edge driver so i dont bother)
Any idea what might be causing this?
Thanks for the edge driver
I still have plenty xiaomi devices to be tested like contact sensor, light sensor and temperature sensor
pairing is tough, you need to keep devices awake by clicking the pair button every 1-2 seconds until it’s paired (can take several mins). but not hold it, so it would not drop the connection a second time.
battery report comes a couple of times a day. and is never precise. just how it is
Yes understand the painful pairing as i was using the old DTH written by the community just can’t get it work with the edge driver, let me try other devices first, i still dont understand even if the xiaomi motion sensor has been paired and worked properly i iust can’t select it in Home Monitor as one of the sensor
Does anyone know if this works for the Aqara smart plug, that also measures energy consumption?
If you mean this one(ZNCZ12LM), yes I have using the edge driver, the only thing missing from it that is available when using the DTH is temperature, otherwise everything else works well.
This is the driver link for the one I’m using.
the linked thread doesn’t seem to contain the plugs though. I suppose you use both that driver you linked, and the one in this thread? It reports power consumption in smartthings as well?
Assuming you mean the ZNCZ12LM I have it running on my v3 hub via an Edge driver, see screenshot below. In this case specifically the Xiaomi plug driver but there are 3 others that picked it up also. With this specific driver I notice that the Voltage isn’t populating but that is okay for how I use it.
Will try the other 3 drivers and reply.
Hi @veonua ,
Would you be able to add support for these two Aqara devices:
D1 Wireless Remote Switch (Double Rocker)
WXKG07LM
Zigbee ID: lumi.remote.b286acn02
Wall Switch (With Neutral, Single Rocker)
Model QBKG11LM
Zigbee ID: lumi.ctrl_ln1.aq1 | lumi.ctrl_ln1
Thank you for all the drivers you already provide!!
Best regards,
Sakari
I am on vacation this week.
But have you tried to pair these devices? as they seem like devices already supported
Tried to pair the first one without success, but I’ll give it a new try. I didn’t find the product codes (WXKG07LM & QBKG11LM) listed at the very beginning of this thread so thought they’d need to be added. Didn’t try to add the wired one yet as it requires electrical work and wanted to first make sure it’s supported.
No pressure timewise, enjoy your time off!
I have 3 of the Aqara Opple switches ( 2 four button and 1 six button) is anyone experiencing that the 4 button ( model WXCJKG12LM) doesn’t respond at first touch? I’m only having the issue with 1 of the switches. Almost everyday I have to press it twice to get a response . This one in particular controls edge driver devices. The other 2 control devices that I have not switched to edge drivers or Wi-Fi devices that are compatible with ST such as Kasa bulbs.
@veonua i know you’re on vacation (hope your enjoying it) hopefully you can look at this when you come back.
TIA everyone for your help with this.
thanks. It arrived today and the driver works. However, update time is quite long, multiple minutes before it reports wattage…Also for you?
@veonua Perhaps it is possible to update the driver to increase speed of reporting?
driver doesn’t anything fancy just translates Zigbee report to the ST format . I doubt it’s possible to control the report frequency for Aqara devices
Thanks! It started updating fine, however the wattage is going up and down like crazy for the connected solar panels. They can give 600w maximum on a sunny day, and today was a cloudy day, and the switch reported figures between 600w and 2400kwh. i hope it’s a defective unit, will try buying a secondary.
