[Edge] Driver for Aqara Switches and Remotes
Reinstalled the drivers, can now use the full extent of the button presses.
However, new issue. I have added one of each of the buttons and they work perfectly. When I add any further buttons, they add fine but aren’t picking up any button presses and therefore don’t complete any of the actions.
Thank you!
i need model names to check this issue
Was there a change on the drivers recently? My Aqara button ( WXKG11LM) stopped working last night and now I see more options on the Smartthings app, (Pressed 3 times, Pressed 4 times, Pressed 5 times).
I removed and readded the device, but I cannot get it to work.
Hi, I’m looking for the driver WS-USC04 (Double Rocker with Neutral Wire).
I’m using a driver for the switch, but when I set a routine it sees the switches as buttons on the THEN, It wont let me choose between On or Off.
Thanks for the help.
I am having the same problem as Infinito42:
My Aqara button ( WXKG11LM ) stopped working last night. I have removed and added the button back, no luck.
I get no response from single click or hold.
Driver version 2022-09-03T07:55:34.672615457
I switched to these edge drivers which work well for single/double click and hold:
Channel invite on this page:
Thank you!
These other drivers worked for me as well.
“lumi.remote.b1acn01” should be working in the new version
(Xiaomi/Aqara Switch and Button v1.4)
maybe I misunderstood something, but there are
two switches “left” & “right” on your screenshot. you can control them
I can control them, but the problem I’m having is that the driver sees the RIGHT and LEFT as buttons.
If make a routine to turn off all the light at night and the light is already OFF it will turn it ON.
The routines won’t let me select which that status I want to be.
oh yes, it seems like the iOS application is broken. sorry, nothing I can easily can fix.
It renders better on Android.
Anyone tried the Aqara Cube driver? :slight_smile:
@veonua do you know if this is working for the wxkg02lm double rocker (stick on)? Thanks very much,
I think yes, give it a try. I have the model like that. but there are also two Zigbee models in with the same name
See previous message
All is working now thanks.
Updated to 1.4 and now all devices are responding as expected.
Hi, does this driver work with Aqara 3Gang Neutral wall switch? I’ve added but the 3gang switch reflect as 1 icon on the dashboard and you need to go into the icon to control left, middle and right button. Which do not really work well when you need to control them individually from the dashboard.
the dashboard view customization is unreasonably difficult, and useless to me as I prefer the GHome dashboard.
The easy way to solve it is to use virtual devices.
You are welcome to create a PR on GitHub.
Are you able to point me to the link to a step-by-step of using a virtual device? Thank you.
try (New Release) Edge Driver Virtual Appliances Mc (virtual Switch Mirror and virtual Switch Board)
