Hi, This is DTH that connects the Aqara wall switch to SmartThings Hub.
I tested it with a model that needed a neutral line. (single rocker and double rocker)
If anyone has a no neutral model, please test it.
And if you have a problem, please provide me with information such as capture.
(my device -> aqara switch)
These devices report power, at least the double rocker w/neutral does. Your DTH should include that capability if the new single rocker supports power. Itâs Cluster ID 0B04/0702, which is in the raw description you posted above.
I believe the new Aqara single rocker should also work with STâs stock DTH called âZigBee Switch Powerâ, but I have not tested that. If so, then this device will be local to the hub and not require a custom handler.
Hereâs the DTH Iâve already published for the double rocker. It has the power attribute, as well as the child devices. Works in both the Classic and new app.
hi!
This dth is integrates many switches released in Korea.
Some Korean or Chinese compnyâs simgle rocker switches registed as âThingâ, forcing users to change dth directly to a âzignee switchâ.
And since Korean light switches use up to six rocker, so it is made to automatically register 1~6 rocker dth once it is registered.
(for convenience)
As you said, the Aqara single rocker switch does not have to install a separate dth, but for the reason described it was induced to install in the video.
and Iâll try the âzigbee switch powerâ dth.
Thank you!
Hi @OhJungTae, that makes sense if you want to use just 1 DTH for any combination of rockers. Based on the raw description from your first post, that switch supports power reporting, so you might want to add that capability for ST users.
FYI @OhJungTae , Iâv updated my DTH for the double rocker to include cluster 0702, which is accumulated energy (kWh) since the device was first joined to a hub. You can NOT reset this kWh value without completely factory resetting the device (which means losing everything and rejoining). More detail here:
all DTH are published in SmartThings account, wall switch is blinking blue after holding down, but neither SmartThings or SmartThings Classic recognize [add] switch when searching, any advice?
Thatâs a super old DTH of mine, so I wouldnât use it.
I donât have that particular switch, but it should join as a Thing using either mobile app. Personally Iâd use the Classic app, but both should work. It is a finicky device, so start the join process on the app and then tap on the switch. If it still wonât join, try a factory reset and try again.
Once it joins, you can change the DTH (Type field) to STâs stock DTH called Zigbee Switch or Zigbee Switch Power, or one of the others youâve mentioned above.
Hopefully someone who has one of these can chime in with more advice.
Thanks for the quick response! Currently (still) searching with Classic app.
Iâm trying to learn about the catchall method but Iâm not having much luck in how itâs used (total noob here). Do I somehow enable it on SmartThings, or is it a git code Iâm looking for?
Previously reset hub after failing to pair with various DTHs; aqara switch is not registering, even with âthingâ on SmartThings classic search. I also tried starting the search first, and then holding down the switch button to trigger pairing mode, but no go.
I also have a DTH written for the double rocker, which also supports displaying power (active watts), as well as energy (kWh) since reset, as well as the capability to reset while saving total kWh since installed (as a device state variable). Booung should probably update their DTH for those capabilities in case an ST user wants to use that in Automations or SmartApps.
My switch goes into (what Iâm assuming is) pairing mode: I get a blue light flashing and the physical switch becomes non-functional.
Oddly enough, I was able to pair the Temp/Humidity sensor just now (using @johnconstanteloâs code, as it was the most up-to-date one I could find for that device). Now Iâm wondering if the switch is somehow defectiveâŚ
EDIT: not sure why I didnât think to bring this up earlier or whether itâs at all pertinent, but the switch does not leave pairing mode; I have to reset the breakers in order to regain âdumbâ switch functionality.
So, I bought the Aqara hub hoping to get the switch paired up and then be able to pair it directly to my SmartThings hub and the damned thing didnât want to pair with the Aqara hub either!
Thanks to everyone for taking the time to help, it appears to be a hardware issue, Iâm returning the switch.
I know its been since June since anyone said anything but i just used the DTH from the above video for the WS-USC01(No Neutral , Single Rocker) and it work perfectly no issue. Thanks for the post and DTH
