and what supposed to be done with this information ?
Could you explain your problem in a few sentences in plain English?
Additional information for knowedgeβ¦
for some Aqara ButtonΒ΄s not listed until now in this topic.
Could u, please, add support for WXKG06LM , WXKG07LM, QBKG38LM and QBKG39LM?
Feel free to message me if u need any specific information about these.
fingerprints added,
WXKG06LM, WXKG07LM should be working better. as they already were implemented, and likely tested by the community
please send me the logs in PM if something is missing
Can you please add a fingerprint for WXKG11LM Wireless Mini Switch:
deviceLabel: WXKG11LM Wireless Switch
manufacturer: LUMI
model: lumi.sensor_switch.aq2
deviceProfileName: button
done, not sure if the profile is right. but it should pair now
Andrew,
Are you able to make an Edge driver for this Aqara Outlet? The driver that Mariano made only works for on/off and not for power, energy and temperature.
Thanks,
Nick
as far as I can see itβs already there. Have you checked the plug and outlet driver?
The power meter says βOut of Rangeβ and the energy consumption shows a βNo Cloudβ
Using this driver
this is not my driver. The view with βRandom On Offβ is from Mariano
Yes that is correct he suggested that I contacted you his explanation was in the link I sent you
Thanks, that works for what I need.
Hi how do i add your DH into repository? What should i put under Owner and Name?
just scroll all the way up, there is an invitation link
Hey, thanks for adding support for the WXKG11LM Aqara button.
On my previous DTH I had the ability to have button press, press x2, press x3 and press x4 but it is only allowing me press, press x2 and held at the moment. Do you think this could be added?
there are two WXKG11LM exist
lumi.remote.b1acn01 and lumi.sensor_switch.aq2
please let me know which model you have
Ah it appears I have a mixture of both types.
Iβve changed just one button over to local so far.
Iβve just tried adding the lumi.sensor_switch.aq2 but itβs not allowing me to add it like I did the other version. Just says cloud on the ide and not placeholder.
Is that a fingerprint issue? Thanks
try to reinstall the latest version of the driver, maybe there were an issue with ID duplication
