Changes in profile preferences, adding new options in enumerations, changes in the text description… when the new version of the driver is generated, they are not applied.
Yesterday added new option to preferences change icon and not appears in the new driver version
I don’t know what has changed, this worked perfectly, only you had to clear the app’s cache and now you have to create a new driver ID to show the changes in the profile.
Hi, @Mariano_Colmenarejo!
Thank you for reporting this. Just to have a better reference for the issue, the driver isn’t updating despite you installing it directly and not through a channel invitation, right?
Sorry for the delay checking this issue, I’ve been making some tests with the preferences and the updates come in. I changed the description, added more enums (or preferences)
Is this keep happening with your driver? have you verified that the driver version shown in the app matches the last one you built?
Sorry, I didn’t tell you on Friday but I was able to replicate the issue. I used your config and also, in the one I was using, it started to happen when I tried to configure more than 4 enums. I don’t know if the quantity is related.
What I noticed is that it also gets updated if we add a new preference.
Either way, I already reported this issue because I queried the generated device profile and noticed that it isn’t updated there as well.
Hi, @Davec
Yes, it is still present. What we’ve seen in other cases is that adding/changing the preference’s description triggers an update, so, it can help you out.
