( I’ve moved this to projects so you can get responses based on your individual set up and requirements.)
I’m not sure you’re going to be able to get an individual playlist to start unless you add an additional device which actually speaks a command that the echo will respond to. But @bamarayne should know one way or the other.
For a Hue scene, Of course the echo can do that but it can’t combine it with the other command. However, @bamarayne may have some ideas on that as well.
Alternatively, it’s possible that core can do some or all of this.
You can definitely get to Hue scenes through IFTTT, but while Spotify has a channel, it doesn’t let you start the specific playlist, so that doesn’t help.
Anyway, I’m sure the community can come up with some creative approaches.
