I previously had a number of Fibaro Dimmer 2’s connected to my SmartThings hub. I recently tried to add 2 more, but whilst the pairing initially seems successful (device shows up in the App after the pairing session, no error messages are displayed)…
- I cannot control them via the SmartThings App (any operation just times out)
- The App does not reflect any correct status
- The SmartThings Graph website shows the networkSecurityLevel as ZWAVE_S0_FAILED.
I have tried;
- Resetting the new devices multiple times and re-attempting the pairing
- Moving the hub closer to the devices (it’s now 2 feet away)
- Restarting the hub
- Factory resetting the hub
… now, after doing a factory reset, the old Fibaro Dimmer’s (which used to be paired and work absolutely fine), now fail with the same behaviour
The debug logs for the pairing session shows nothing obvious (only a 1 line entry from the Fibaro, saying it was “installed”);
Does any one know what else I can try?
or EU
