I just got the dome siren (pretty slick little device) however, I have one complaint. The siren has a delay which is pretty darn awesome especially since it will beep to tell you it’s in the pending state. However, if I tell it to repeat the beep x number of times, it beeps that number of times very rapidly then is quiet until the siren sounds.
A preferred operation would be to beep perhaps every couple seconds for the period of the delay. I’m in the process of combing over the dth hoping to remedy this, but thought I would drop a line to see if anyone can tell me if this is proper behavior or a bug. Or if you have found a work around yourself. Thanks.
@krlaframboise (thought I might tag you since you wrote the dth hope you don’t mind)
You will get the fastest answer if you ask your question in the author’s thread for that particular DTH. The author will be automatically notified when new posts are made there and other people who are using the same code may also be able to help. In this case, Ask your question in the following thread:
