Do we know if a TCP update is coming?
Are we closer to an update for this?? I have over 30 TCP bulbs connected to ST’s that I’d really love to use without the known issue!!
What issue are you referring to? I’ve been using it without much problems.
Using more then 3 bulbs on hello home actions without an issue.
I think he’s referring to the issue where more than 3 bulbs are installed in close proximity (same light switch) and used with ST, there may be unpredictable behavior (not all bulbs turn on/off)
Yes @JAA that’s exactly the issue!!
@antman2 Dealing with the same issue in our home.
Frustrating to say the least! I have 30 bulbs, but 21 are connected to ST’s and I can’t use them with any Apps in ST"S.
I was told update 11.705 would help with the TCP bulbs? Have you noticed an improvement?
Slightly off topic… Do any of your tcp bulbs buzz? All mine do and I think I am sending them back in favor of the ge link bulbs. I have 5 of those and they are great so dar, have more on order to replace the tcp bulbs…
@Macadoodle
I have 5 tcp connected bulbs, no noise at all… I like them.
Mine don’t buzz… @Dave do you have them hooked up to a dimmer switch??
Strange - every single one I have (I have 4 br30s and 3 Edison) all buzz. It’s only really audible if you’re right under the light or very close by, but it’s very noticeable.
None of mine buzz but I like the GE bulbs better.
Yeah - I wonder if I have a bad batch? 2 buzz but I’m sure it’s because of an old dimmer but then the others aren’t on dimmers - and one, which is on the same circuit as 2 others, doesn’t buzz…strange. I’ll hold on to these until the ge ones come in (estimated delivery sometime end of sept) but then they are going back to homedepot!
