Disable triggers
Hello there,
I was wondering if i could disable my motionsensors when im away. This is for the animals not to trigger it.
I would also set a day as exception for housekeeping,
any suggestions?
greetings
Need more details about how you’re currently “triggering” your motion sensors. Basically which smartapps have you setup and what kinds of automations have you created in those smartapps that make use of your motion sensors?
Do you use smart home monitor? Smart lighting? Any routines?
I use smartlighting… and routines i use based on whether im away
So all lights, and other ‘things’ turn off.
restrict the smart lighting rules to not run in Away mode.
What he said
:grin:
Was right under my nose… thanks guys^^
