Is there a guide somewhere that tells you how to actually get the SmartThings dimming outlet to dim a lamp? I was able to get it setup in ST and it works to turn the lamp off and on with my routines but I would like it to turn on at like 50%.
After closer investigation apparently I just have the regular outlet. I was sure it said dimming outlet on the box. I will double check when I get home but looks like I got the wrong one. Not a big deal I guess but it would have been nice to be able to dim the lamp a bit. So apparently if I had the dimming one a setting would show up in ST that would allow me to set the lighting level?
It might have also been added as the toggle switch and not the dimmer in the ide and might require you to change it. I noticed the toggle/dimmer devices sometimes do this.
