I’ve been looking for a way to have lights dim gradually for when we need to go to bed in the house. Is there a smartapp, or some way have to lights go from “Whatever dim-level it is at now” to something else like “40%” dimness over a period of time.
Right now the only thing I have is a routine that just throws the lights on and dims them to the needed %, but that is a very rough transition from normal brightness to dimness in the living room, a gradual way would be much better.
You can set the dim rate in the edit device under things, that has it dim over a couple seconds ( better for light’s health) rather than an instant change. I think you want it to dim over a few minutes, which would require a custom app I assume.
For what device type are these settings? I am using “Dimmer Switch” for GE12724 and the only options I see are to change name and icon (icon actually does not work).
I have it on my GE bulbs, Cree bulbs and Leviton dimmers ( both wall and module) . So I assumed it was standard on all dimmers. I make no claims about Hue .
