When I set a house mode (Home, Away, etc.), I want to be able to set different temperatures on different thermostats. For example, one temperature setting for the main floor and a different setting for upstairs. Right now your app only allows for one temperature setting for both thermostats.
You can install multiple “keep me cozy” instances and do it that way, then set each one to control a single thermostat
Dashboard, hit + at bottom, swipe over to More, Green Living, Then choose Keep Me Cozy or Keep Me Cozy II, And then Install. Give it a name (like Zone 1) and configure it for just 1 thermostat.
Repeat the above, give it a different name (Zone 2, perhaps) and configure it for the 2nd thermostat
Should work just fine!
Thanks for the workaround.
I made a Setpoint manager. Right now I have it setup to have a different instance of the SmartApp for each Thermostat, but it can have several setpoints for mode groups.
Thank you for the info.
