Thermostat Setpoint Manager
(Eric R) #1
I know you can use Hello, Home phrases to set thermostat setpoints, but it doesn’t allow you to do different thermostats at different temperatures for the same phrase and I also find them a pain when I want to change them. So, I created the Thermostat Setpoint Manager.
TSM changes both the heating and cooling setpoints for a thermostat (or set of thermostats) based on mode. You can assign the same setpoints to a group of modes to minimize on entering a bunch of stuff. If you want different setpoints for different thermostats, you can use another instance of the SmartApp.
I’ve been testing it for a few days and have not run into any problems. Let me know if you see anything that needs to be fixed. Enjoy!
https://github.com/baldeagle072/thermostat-setpoint-manager/blob/master/thermostat-setpoint-manager.groovy
Different temperature settings on different thermostats
(Jeff DeWolfe) #2
I definitely plan on trying this! Thank you for sharing. Will let you know if I run into anything weird.
(Suresh Vilayanur) #3
Did this work for you?
(Suresh Vilayanur) #4
@baldeagle072
Eric I cannot find this code anymore…do you have an updated link?
Does anyone have a copy of this code? I’m having problems with Alexa setting temp in auto mode that causes a battle between the fireplace and thermostat due to the heating and cooling setpoints being the same.
(Eric R) #6
(Suresh Vilayanur) #7
Eric,
Just out of curiousity…im not a coder why does your code say " Delete thermostat-setpoint-manager.groovy"
Why delete? and it shows up in red?
I know how to cut and copy the code, but didnt want to inadvertently delete something. Thanks!
(Eric R) #8
I’m not sure where you’re seeing this.
(Suresh Vilayanur) #9
Not sure why it was either, there was a toggle that when I switched changed the view back to the code and got rid of the “delete”. Anyway I have installed this and it seems to be working great!
Thank you!
A few quick questions. If you edit the number of groups does it over write all the groups or truncate/expand on the existing groups? I have not checked…
If a mode change occurs and the group does not exist, does the thermostat still use the setpoints from the previous/last mode?
